Old 02-04-2019, 04:04 PM   #1
demian5
demian5's Avatar
1960 truck fan shroud
Is there a shroud that will fit a 60 with the stock size radiator? The truck has a small block in it and a flex fan and no shroud (solid mount fan with no shroud is factory...right?).
I have has great luck with a shroud and a fan clutch on all of my other older vehicles.
Suggestions?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-04-2019, 09:24 PM   #2
LVPhotos
LVPhotos's Avatar
Re: 1960 truck fan shroud
With all the mods I went with the Flex-a-lite Black Magic 180 (3300cfm). With out controller, used one from Speedway Motors that piggy backs temp sender. Used original tabs. You can make a box style or tri 5 chevys use same style shroud.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-04-2019, 10:51 PM   #3
Brad54
Brad54's Avatar
There are three different factory fan shrouds for '60-'62 trucks.
The first looks like a '58-'60 passenger car "Barrel" type shroud.
The second is more of a full-shroud that covers the whole core.
The third is wider and has an area "notched" to clear lines for automatic transmissions.
They show up here every once in a while, and show up on Ebay too.
I don't know if there is a difference between 6 and 8 cylinder applications, or even if there are more versions.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 02-05-2019, 11:56 AM   #4
demian5
demian5's Avatar
Nobody makes an aftermarket one?
1986 C20 Scottsdale
Instagram: C10sofOC
Old 02-05-2019, 01:21 PM   #5
LVPhotos
LVPhotos's Avatar
Try the 55-57 Chevy Bel Air. They look to be same radiator.
https://www.danchuk.com/ItemForm.aspx?Item=16626A
Old 02-05-2019, 04:33 PM   #6
Brad54
Brad54's Avatar
Not that I've seen.
Old 02-05-2019, 08:43 PM   #7
72cs20
The 63-66 factory style shroud adapts well to the 60-62's.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 02-05-2019, 09:34 PM   #8
duallydude63
i have a barrel style shroud if U interested??
duallydude63 is offline   Reply With Quote
Old 02-13-2019, 01:45 PM   #9
demian5
demian5's Avatar
Any pics?
1986 C20 Scottsdale
Instagram: C10sofOC
Old 02-13-2019, 08:26 PM   #10
72cs20
Take a look at the link in my sig. Page 3 and 4 I believe.
Old 02-13-2019, 09:02 PM   #11
duallydude63
will try to post pics later 2day !!!
Old 02-13-2019, 10:17 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
A couple related threads :
http://67-72chevytrucks.com/vboard/s...ghlight=Shroud
66 C20 Service Truck:
Old 02-14-2019, 12:22 AM   #13
duallydude63
having trouble posting pics will try again 2marrow!!
Old 02-14-2019, 02:40 PM   #14
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
T
There is a difference between 63-66
6 and 8 cylinder. The 8 cylinder you can find , the 6cyl seems only came with A/C equipped trucks and are impossible to find. The medium duty and heavy duty 6 cyl shrouds are not the same as the light duty..
Old 02-14-2019, 03:22 PM   #15
demian5
demian5's Avatar
The truck I have is a long water pump. Will that make a difference without changing everything over to short?
1986 C20 Scottsdale
Instagram: C10sofOC
Old 02-14-2019, 04:56 PM   #16
72cs20
Thats no problem. Mine was a long water pump also.
Old 02-14-2019, 07:08 PM   #17
demian5
demian5's Avatar
So you added the 63 and later side panels to a truck with a 60-62 radiator and then trimmed the shroud to fit?
1986 C20 Scottsdale
Instagram: C10sofOC
Old 02-14-2019, 10:25 PM   #18
duallydude63
see pics
Old 02-14-2019, 10:45 PM   #19
72cs20
Yes, the 63-66 side panels and shroud to a 62 truck with a 60-62 radiator. It worked very well and looked good too.
If you decide to go this route and need more fitment details, just ask.
Old 02-16-2019, 02:01 PM   #20
paulspickupparts
Originally Posted by duallydude63 View Post
see pics
Rare Bird
paulspickupparts is offline   Reply With Quote
Old 02-19-2019, 06:02 PM   #21
demian5
demian5's Avatar
This is what I would do. Clean, uses OG parts and simple.
1986 C20 Scottsdale
Instagram: C10sofOC
