Old 02-04-2019, 05:56 PM   #1
my67c20
Incorrect Speedometer Reading
TH350 trans, 3:73 rear gear, 29.5" tires, speedometer ~10 miles fast, verified by a GPS at different speeds. I tried some of the online tools, nothing made me feel confident in what they mentioned. Not 100% sure of size of output shaft on trans, apparently there is 1.84 & 1.76. Hard to tell colors from pictures, but looks like brown on trans (drive) and natural (driven) on end of speedo. However, no charts mention the brown drive gear, so it makes it difficult to calculate. Help is appreciated and I did search, but nothing really relevant was found.
my67c20 is offline   Reply With Quote
Old 02-04-2019, 07:25 PM   #2
OregonNed
OregonNed's Avatar
Re: Incorrect Speedometer Reading
Mine was off the same way at approximately 10 MPH fast. I can't remember what color gear I put in, but as soon as I did with that one change my problem was fixed. I bought the set of gears on Ebay, and I can look at what I have left by process of elimination.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 02-05-2019, 09:23 AM   #3
my67c20
Did you just swap out the driven (small) gear until you achieved success? I see that i can get all drive and driven gear sets off of e-bay, but before I tear into the trans if I can achieve easy success first, that is always desirable.
Old 02-05-2019, 09:49 AM   #4
geezer#99
geezer#99's Avatar
I’ve always done the short cut.
Used a ratio adaptor.
Like this.
https://transmissioncenter.net/shop/...ratio-adapter/
geezer#99 is online now   Reply With Quote
Old 02-05-2019, 12:47 PM   #5
tdangle
tdangle's Avatar
You can also use this calculator.
http://www.tciauto.com/tc/speedometer-gear-calculator/
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 02-05-2019, 02:07 PM   #6
OregonNed
OregonNed's Avatar
Yes, just the driven gear. I meant to look in the garage this morning at what I used, but the snow and ice event messed things up. Will take a look tonight, however..
Old 02-05-2019, 02:53 PM   #7
kwmech
It's not really 10mph fast, it works on a percentage. So you'll have to reduce by that percentage that it is off. The speedo says you're doing 60 but Gps says 50 then you have to slow it down by 17%
Old 02-05-2019, 04:36 PM   #8
RichardJ
Back in the day, speedometers on American cars were never very accurate. Car magazines doing road tests on the new cars as they came out, used a device they called a 5th wheel, to determine the speedometer accuracy. They did this routinely on every car and truck they test drove. They usually complained how European and Japanese cars faired better.
American manufacturers did this partly by design. Every knuckle head that bought a new car had to go out and do 100 mph for bragging rights. Speedometer error allowed them to not be as much of a dumb-ass as they thought they were. A built-safety margin. Besides, most European and Japanese cars in the 50s and 60s could only do 100 down hill. Ha !
Instead of going to the garage and finding an old car mag showing a 5th wheel picture to scan, I thought I could just do a simple google search. Google just could not get past 5th wheel trailers, but eventually I found these.
After steel bumpers went away in the 70s, they hung the 5th wheel off the rear wheel well openings on the side of the car. That finally gave way to radar guns and now GPS.
In 1970 if you found out your truck speedo was 10 mile off, you probably wouldn't give it a second thought, unless your glove box was full of speeding tickets.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 02-05-2019, 10:22 PM   #9
OregonNed
OregonNed's Avatar
I can’t seem to find the gear selection set I bought on EBay - but they are very easy to swap and road test. I used a GPS app to decide on the selection. I just can’t remember how many teeth were on my selection.
Old 03-01-2019, 11:44 AM   #10
my67c20
FYI, for others. So i bought the gears shown in the picture. From what i can tell, my original was natural @19 teeth. With this gear and the brown drive gear, my speedo was reading high by about 10 mph. I swapped out the driven for the gray @ 22 teeth and now the speedo is reading high by about 5 mph, which I can live with, until I feel like I need to remove the tail shaft and change the drive gear to something with less teeth. Hope this info will help others.
Old 03-01-2019, 11:51 PM   #11
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
I swapped my 3.73 for a 3.08. My speedo was reading 76 MPH when the gps said I was doing 60. I tried to get a driven gear to correct that but they didn’t exist with my drive gear. I determined the percentage the speedo was out and had an adapter made. Speedo is now bang on with the gps.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 03-04-2019, 12:28 AM   #12
rockyrivermark
Yes. Just buy this set or similar which is cheap. The driven gear can be changed out in 5 minutes.
Download a gps speedometer app on your phone and change them out until you get one that's real close.
https://www.ebay.com/itm/TURBO-TH350...YAAOSwm79ceoEN
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 03-04-2019, 01:37 AM   #13
rockyrivermark
Awesome pic. I just picked up a '67 cougar to restore last month
My build page
Old 03-04-2019, 12:57 PM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
Old blue came with this sweet conversion table.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 03-04-2019, 01:22 PM   #15
painterljp
Subscribed for reference. Thanks.
painterljp is offline   Reply With Quote
Old 03-04-2019, 08:11 PM   #16
Canuckvetter
Very close to mine. I slowed down the speedometer with an 18% reduction adaptor.
Old 05-31-2021, 09:10 PM   #17
Breadstick
Reviving an old thread, my speedometer reads about the same percentage slow as your does fast in relation to the GPS. Will switching the speedo gear still fix it?
Breadstick is offline   Reply With Quote
Old 06-01-2021, 12:13 PM   #18
TBONE1964
Cluster King
TBONE1964's Avatar
I know this is old but will shed some light on the issue.
Number one and easiest way to check speedometer accuracy.
Find yourself a spot where you can drive a measured mile. ( like on a freeway with mile markers). Drive one measured mile. You should see odometer move exactly one mile. If the odometer reads more than or less than a exact mile, then your speedometer gears in the trans are the issue.
If it matches an exact mile, your trans gears, gear ratio and tire size are correct. If your speedometer (needle) reading is off, then the speedometer needs calibrated.
If you need more clarity on this, let me know.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 06-02-2021, 11:17 AM   #19
my67c20
Yes, switching the gears did help, but then something went twang and now i just go slower than the fastest guy, so he can get the speeding tickets. When i am interested i use an app called Speed Box. When i do my Sniper upgrade, its on my list to tackle this issue as well.
