Old 02-05-2019, 02:24 PM   #1
kazoocruiser
How could this be done?
Here is what I would like to do. I would like to use my truck as a charging station to pre-charge a new 19AH 12v lead-acid battery. The battery will fit under the hood, so location is no problem.
According to the instructions, I need to have a 1 amp charge-rate for 19 hours.
1981 C-10 Longbed, 250 (4.1) 2bbl Varajet, THM-350C.
Some of the Build progress:
https://www.youtube.com/channel/UC_W...foLyeDq_WQPNmA
1981 Harley Davidson.
Credentialed, semi-retired A.S.E. technician. If you don't like free advice, Ask Someone Else and pay for it.
kazoocruiser is offline   Reply With Quote
Old 02-05-2019, 02:36 PM   #2
kipps
Re: How could this be done?
Assuming the 1 amp charging rate is critical, the only way to make that happen is to adjust the input voltage until that 1 amp rate is reached. It's likely to need adjusting throughout the day, so there would need to be some sort of feedback loop to adjust the voltage and charging rate automatically.
I'm assuming a simple battery minder type charger would do perfect. Some auto parts stores keep their new to-be-sold batteries on these chargers all the time. If you're good friends with one of these stores, ask if they can plug your battery in for a day. Of course, if you bought the battery somewhere else(online?), I can understand you being a little embarrassed to ask them for favors...
The only route I can see to charge it cheaply and manually, would be to use a ammeter(from a early squarebody), a variable resistor, and a 15 volt power source of some sort(possibly an old fashioned non-automatic battery charger). Set the thing up in your basement on a saturday, and adjust it every hour to keep the ammeter in the 1 amp range.
kipps is offline   Reply With Quote
Old 02-05-2019, 03:00 PM   #3
kazoocruiser
Thank you for your response. If I hooked up the battery I need to charge in parallel with my existing truck battery, and left it alone, not running the engine, would that allow for a slow charge into the new battery without damage? Just hook it up, and leave it alone?
Old 02-05-2019, 09:51 PM   #4
kipps
I have no way of knowing. Anything is speculation unless you have a ammeter in the circuit.
Old 02-05-2019, 10:16 PM   #5
sweetk30
sweetk30's Avatar
NEVER good to mix and match battery types and or cca specs and or mfd codes .
newer non lead acid battery types take a specific charger unless there up to charge and in a working vehicle.
mixing brands / cca / older to newer age / and so on can lead to problems in short order .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-05-2019, 10:22 PM   #6
kazoocruiser
I admit my ignorance regarding all things Ohm's Law.
I sure miss Radio Shack.
I wanted to convert a 4 D cell Mag-light to a rechargeable unit using the cigar lighter and the guy rattled off a how-to answer in less time than it took me to type this.
Old 02-06-2019, 07:42 AM   #7
Dead Parrot
Parallel is a bad idea. If the flashlight is near dead, you would get a very large initial current from the truck battery into the flashlight. Lead acid batteries can both put out and accept large amounts of current, more then enough to melt the average non-battery cable wire. Why they are still used after all these years to power the starter.
Sounds like what you need is a DC-DC voltage converter powered by the truck battery. Feed the output of the converter into a current limited charger for your flashlight. Make sure to include a timer/auto shut off or you might need a jump to the the truck started.
Dead Parrot is offline   Reply With Quote
