60-66 Nut
![]() ![]() Join Date: Mar 2007
Trailing Arm Mounts
A member PM'd me about the dimensions for installing the trailing arm mounts on a later model differential for a '63-'66 but I wanted to post that info here for everyone's benefit. This will actually be correct '63-'72.
The front holes of the trailing arm mounts are 39" center to center. The rear holes are 41.250" center to center. The pinion angle is up 14 degrees. If the trailing arm mounts are level the face of the pinion yoke will be at 76 degrees.
Re: Trailing Arm Mounts
Thaks CaptainFab!
