Old 02-06-2019, 01:12 PM   #1
EPS3
Toe-out on turns
I'm hoping one of the experts on C10 trucks here can help me out.
I'm considering using a front steering Chevy C10 cross member (or at least control arms) on my 1937 Buick Hot Rod.
An old hotrodder on a different website conveyed the following warning:
"The Chevy C10 steering assembly doe have a minor fault with its design. The problem is that most of them do not produce enough toe-out on turns. Here is and example; if you were to turn the left wheel 20 degrees, the right wheel should turn 22.5 to 23 degrees. Most C10's won't do that but otherwise they will last forever."
Does anyone know if this true of all C10 years?
Is there a fix that can be made with set-up to correct this?
I apologize if this has already discussed, but did not see a reference when I searched the topic.
EPS3 is offline   Reply With Quote
Old 02-06-2019, 01:54 PM   #2
rpmerf
rpmerf's Avatar
Re: Toe-out on turns
I believe what you are referring to is Ackerman angle.
https://en.wikipedia.org/wiki/Ackerm...ering_geometry
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 02-06-2019, 03:29 PM   #3
EPS3
OK that makes sense.
Thanks for your help.
Old 02-06-2019, 03:39 PM   #4
wilkin250r
wilkin250r's Avatar
I'm not sure I would worry too much about the Ackermann geometry. At slow speeds, it's not a danger because, well, you're going slow. At high speeds, the slip angle of the outside wheel becomes much more significant, and any designed Ackermann geometry goes out the window.
I think the other aspects of your steering geometry would have a much larger impact, like camber, caster, and scrub radius.
I couldn't tell you specifics about the C10, however, my experience with steering geometry comes from racing sport quads.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 02-06-2019, 04:08 PM   #5
EPS3
Thanks for the feedback
