Electric fans & Vintage Air
I have a 2006 LQ4 with electric fans that are activated by the PCM. They are wired with a factory harness and relays from an Escalade. Since fans are enabled in the pcm, if I connect the A/C request wire from the harness to a 12v source when the A/C is on will the fans function as they should from the factory or do i need a trinary switch?
Where exactly should the request wire be hooked up? |
| Bookmarks |
