Old 02-07-2019, 01:20 PM   #1
Tony71c10
Looking for pics 5/6 rear coil drop
Im undecided on my rear drop, not wanting to c-notch. Wanted to see if any one could post any pics of how much room you have from the axle to the frame you have with your drop in the rear. I have a swb with a missing wood floor. My truck is not a daily. Any pics are appreciated.
Tony71c10 is offline   Reply With Quote
Old 02-07-2019, 01:43 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: Looking for pics 5/6 rear coil drop
Sorry I don't have a pic to post to show you, but I am running the ECE 6" drop spring and don't have a C-notch and don't need one. Talk to Early Classic and they will guide you. I'm sure if I slammed a speed bump or something I would hit the rubber stops, but I plan to go slow...over speed bumps.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-07-2019, 02:34 PM   #3
TruDom
ECE 6" drop coil springs in the back, no notch. its about 3" between axle and frame.
i wanted the spacing between the tire and fender curve to be equal the whole curve. it is... hard to see in pic.
http://67-72chevytrucks.com/vboard/a...1&d=1548989450
TruDom is offline   Reply With Quote
Old 02-08-2019, 10:02 AM   #4
68Stepbed
68Stepbed's Avatar
This isn't my current stance, but when I used to have a 4.5/6.75 drop and no c-notch.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-08-2019, 09:23 PM   #5
zicc1835
zicc1835's Avatar
six inch drop ...maybe when I put the fleet side bed with wood floor and cab back on it drops a hair more ?
zicc1835 is offline   Reply With Quote
Old 02-08-2019, 09:31 PM   #6
zicc1835
zicc1835's Avatar
beautiful truck by the way.......is your bed steel or wood ? looks like my frame at the moment is just under 4 inches above the axle . no exhaust installed yet no fuel in the tank. I cant imagine that dropping the frame a whole inch ....i will come back to this thread and report when i get it all back together maybe late spring
Old 02-09-2019, 04:50 PM   #7
Tony71c10
Thanks for the pics, and comments everyone
Old 02-09-2019, 11:40 PM   #8
TruDom
thanks. steel bed.
just measured 2.25" between frame and axle.
not sure why mine is so low. good thing i dont plan on towing. honestly just got it together havent driven it on the road besides around the block. could always add an inch block if i bottom out more than i like. (before i get around to c-notch)
