kickdown cable trouble
I need some help with this. The truck I just bought had the kickdown cable just sitting there. Its a 81 Chevy SWB w/ a 305HO and a TH350 trans. It's almost all original with low miles. The problem is that it had the wrong carb on it and I think that the last owner was trying to hookup the cable like it shows in the pic I have posted. The problem is that the cable is at the bottom of the bracket and the post it is to be mounted on is at the top of the lever which puts it at a bad angle. All the other trucks I have seen show it to be mounted at the bottom of the lever including my other truck (but I'm running an edelbrock). I am posting another pic also that I found on here from somebody else's post. It shows the cable hooked up the way I have it on my other truck, so the kickdown works opposite the throttle. Thanks
Another thing, the end of the cable (that long oval slider thing on the end made out of steal) mine is almost twice as long as the one in the pic above.
The pic above is where I have seen them mounted before. On my other truck the end is cut off and the wire is put through this thing with a set screw that snaps on to that stud. I have never had a problem with it. I don't know what the best way is to mount it is. I do want to mount it. I don't want to down shift all the time. Thanks
Stylin
ill be watchin this one cause my kickdown cable just has this little piece of crap button looking thing thats cut in half
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
LED King
Am I mistaken, or do TH350s not have kickdown cables? Don't they have a vaccum modulator? It could be that your truck was originally equipted with a TH700R4 and for some reason the previous owner left the cable on there.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
It has a cable as does my 86. The 400 trans don't have cables.
Stylin
th350's have modulators and then a kickdown cable that when u romp on it, it kicks it down to 2nd or first depending on how fast your goin
Either way I need to know how to hook up the cable.
I have a similiar problem with my kickdown cable. I have adjusted it like my haynes manual said and it does not kick down, needless to say i dont take the truck in passing situations.... Do i need to get a new vacuum modulator?
-79 Bonanza C10 305 t350- --Needs front clip...LOL-- Cant stop the heartbeat of a Chevrolet. |
Stylin
i wouldnt think so if the truck is shifting, the kickdown cable pulls something in the valve body and makes it shift down a gear. might try it modulators around here are only like 12 bucks and then u get to go threw the pain of adjusting them
