Old 02-08-2019, 12:19 AM   #1
racerface
1981 STD gear ratio
HELP! I am working on a 81 C-10 two wheel drive 10 bolt with some rear end issues. Build tag said that is a GQ1, STD RATIO. Question is what is the standard ratio? I have a 10 bolt GU4, 3:08 gear in it and would like to use it if it's close to the GQ1.
Racerface
Wellington, Ohio Freedom Isn't Free!
GO BUCKEYES!!!
Toys: 68 C-30 327-400turbo
68 C-30 Open Road Camper 327-400turbo
81 GMC Sierra 1500 250-350turbo Long Bed
83 K-10 4X4 Scottsdale
racerface is offline   Reply With Quote
Old 02-08-2019, 02:37 AM   #2
Big Moose
Re: 1981 STD gear ratio
Did you look at the plate on the diff itself?
Big Moose is offline   Reply With Quote
Old 02-08-2019, 07:50 AM   #3
Dead Parrot
Unless you know the history of the truck back to first sale, don't trust the build tag. A PO could have changed the gear set.
Simplest is do the spin the tire, count the drive shaft rotations test.
If the rear end is off the truck, just count teeth on the gears.
Dead Parrot is offline   Reply With Quote
Old 02-08-2019, 08:20 PM   #4
racerface
At the moment axle is still in the truck. The truck has been in family since 1981. Guess I'll do the old rotation trick. Just thought it was odd GM just calls it "The STD Ratio". Thanks for your time Big Moose and Dead Parrot, stay warm!
Racerface
GO BUCKEYES!!!
Old 02-08-2019, 09:08 PM   #5
Keith Seymore
Keith Seymore's Avatar
Need more detail in terms of engine and trans but the "most base" ratio is 2.73 .
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
(Powertrain charts shown on page 12 - California only - and page 13 - all others - of the pdf)
The reason the base axle is not called out specifically (designated by GQ1) is because it changes numerically based on other powertrain considerations, per the charts.
The optional axles get called out by name because the numerical ratio always stays the same as the RPO code.
Bottom line is, as Dead Parrot said, no telling what's in there after all this time.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-11-2019, 07:25 PM   #6
racerface
Thanks Keith for the reply. It's a 250 - 6cyl. 350 turbo Hydro farm truck. I'll check out the GM site, thanks again.
Racerface
GO BUCKEYES!!!
Old 02-11-2019, 09:11 PM   #7
Keith Seymore
2.73:1 Federal; 3.08 for California emissions.
K
1979-1986
1986 - 2019
Old 02-12-2019, 06:21 PM   #8
dagnabbitt
dagnabbitt's Avatar
Mine's an 81 6 cyl (originally) I can confirm that it would be 273
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 02-15-2019, 01:09 AM   #9
akart
So,like rotate your wheel and count how many times the shaft rotates. Done!
There's your ratio.
akart is offline   Reply With Quote
Old 02-15-2019, 05:28 AM   #10
mongocanfly
Post Whore
mongocanfly's Avatar
well ....sorta akart....https://shiftsst.com/articles/how-to...ear-axle-ratio
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-15-2019, 06:16 PM   #11
akart
Originally Posted by mongocanfly View Post
Thanks for setting that straight. Good answer.
akart
