Old 02-08-2019, 02:55 AM   #1
stomper
Junior Member
stomper's Avatar
Flip kit bracket too short?
I installed an eBay flip kit tonight. Set the axle in the brackets and the axle rotates. The vertical legs of the 'U' shape don't reach the spring perch pockets. I contacted the vendor and they said, "These are designed that way to set the piñon angle. Once the u bolts are torque the axle will not rotate."
This sounds ridiculous to me! I would not expect the ubolt friction to keep that axle from rotating. I've done 3 others and the brackets lifted the axle off the bottom just a hair. No rotation. Am I wrong?
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 02-08-2019, 12:11 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Flip kit bracket too short?
I wouldn't use those.
Buy a different brand.
I always liked using Belltech.
Keith
Convert to disc brakes.
Old 02-08-2019, 01:06 PM   #3
stomper
Junior Member
stomper's Avatar
I agree but isn't the eBay seller full of it? I spent $100 on these and I think I should get my money back because of a poor design. Not how they are supposed to work. Just plain wrong.
Old 02-08-2019, 01:46 PM   #4
sweetk30
sweetk30's Avatar
file a clam for bad product on ebay or paypal if they dont play hardball .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-08-2019, 02:51 PM   #5
lolife99
lolife99's Avatar
Yes.
I would request a refund.
They probably got a little off when they bent the 90 degree bends in a press brake. That would make the uprights of the flip kit bracket too short.
Plus I like the welded on side pieces that Belltech and Western Chassis uses in their flip kit bracket.
Keith
Old 02-08-2019, 02:53 PM   #6
Wikid61
Wikid61's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=778983
Wikid61 is offline   Reply With Quote
Old 02-08-2019, 03:13 PM   #7
bagged01extcab
Originally Posted by Wikid61 View Post
I bought a set of these from specialtyretail and they fit perfect. He also had great shipping time and customer service
Trey Oney
bagged01extcab is offline   Reply With Quote
Old 02-08-2019, 03:25 PM   #8
stomper
Junior Member
stomper's Avatar
I've bought a set of those from that post in the past. They fit as expected bottomed out in the spring perch pocket.
Old 02-13-2019, 06:58 PM   #9
stomper
Junior Member
stomper's Avatar
Made some proper ones at work. Waterjetted out of 1-3/4" A36 plate. Yes, I'll put a offset hole in them.
Old 02-13-2019, 09:38 PM   #10
cruizin01
I had the same issue with my ridetech brackets. I ended up welding on a tab so I could get the pinion angle I wanted. I wonder if not all axles are exactly the same.
'78 C10 Build
cruizin01 is offline   Reply With Quote
Old 02-13-2019, 10:49 PM   #11
Wikid61
Wikid61's Avatar
Are the wheel/tire combo dead center in the wheel wheels when done?
Old 02-14-2019, 01:29 AM   #12
kwmech
Not that of a big deal. Set it up, set the pinion where you want it and weld them to the housing in a couple of spots. Between the weld and the u-bolts it won't move. Without welding the pinion will eventually work its way up relying on just the u-bolts
Old 02-14-2019, 10:58 AM   #13
SCOTI
SCOTI's Avatar
Yes.
x2.
No welded side brackets = less stability under stress.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-14-2019, 11:22 AM   #14
lolife99
lolife99's Avatar
Most manufacturers of these brackets move the rearend back slightly.
This centers the rearend in the wheelwell after the flip to the top side of the leaf springs.
It also allows the use of the original driveshaft, without shortening the length.
Keith
Old 02-14-2019, 01:34 PM   #15
bigblock73
yeller
bigblock73's Avatar
You get what you pay for. As stated above, Bell Tech, Western Chassis and others are a much better design.
bigblock73 is offline   Reply With Quote
Old 02-14-2019, 03:43 PM   #16
Wikid61
Wikid61's Avatar
I'd like to see each companies flip brackets. Laid out side by side. Then standing upright side by side. Measurements recorded. Then fitted into the application. My 1st flip was 30 years ago w/Trailmaster. They had a 2" inch coil you could cut a 1/2 wrap and it was a solid 3". Rode killer fine. I still have a pair to dig up and pix.
Old 02-14-2019, 10:40 PM   #17
cruizin01
I understand what your saying but I dont think the height of the bracket effects that. At least in my case where you use the alignment pin and keep the bracket flat against the leaf. Obviously you can move the hole in the bracket front to back to get the axle centered.
These are the RT brackets. If you look closely you can see they dont even come close to hitting the bottom of the leaf pad. This caused the axle to turn inside the ubolts when going from D to R.
'78 C10 Build
