Old 02-08-2019, 06:25 PM   #1
72farmer
Need help on correct lower radiator hose on LS swap
I just bought a 68 with LS swap. It did not have inner fenders when i got it. I am trying to put new ones on.
The bottom radiator hose is keeping the inner fender from going up to the bottom of the radiator support. It likes at least 1" and is hitting the hose. I am not sure what the radiator is out of. The bottom barb on the radiator is straight out and measures 1 3/4" in diameter. What molded hose (need part number) would give me the clearance that i need? Please help!!
72farmer is offline   Reply With Quote
Old 02-08-2019, 09:54 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Need help on correct lower radiator hose on LS swap
If you aren't using a stock (or common) rad, no way we'd know exactly which hose will work. If your fitting something custom, just ask your local Napa if you can peruse the rad hose catalog, or ask to look at the hose rack. I pulled a few hoses off the shelf, and returned the ones that didnt' fit. IIRC I started with a stock part, and cut ~2" off to fit my Be-Cool SBC rad.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-08-2019, 10:06 PM   #3
sprint_9
sprint_9's Avatar
Seems like an incorrect radiator as most that Ive seen have the lower radiator hose angled up. Im not sure you can get the stock fender in with a straight hose connection.
sprint_9 is offline   Reply With Quote
Old 02-08-2019, 10:12 PM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
I've not done one yet that I didnt have to either cut off a hose or use 2 hoses to make one...
plus what was said above.....and I'd get rid of that ribbed style hose
You can take a heavy wire and bend the shape you need the hose to be....,take that to the parts store and start looking
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
