Old 02-08-2019, 09:25 PM   #1
jbristo67
resident oilfield trash
jbristo67's Avatar
Rebuilding manual windows.
How deep is this job. What all do I need to do to make them operate like new
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 02-08-2019, 09:57 PM   #2
4x4k30
4x4k30's Avatar
Re: Rebuilding manual windows.
its deep /need regulartors and all of the door window mouldings// new glass is a way to go /the bottom the window sash needs replacing most of them are rusted . its not that big of a job. but if you dont know how to cuss and get pissed off you will learn very quick.
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 02-09-2019, 02:42 AM   #3
Matt Man
Matt Man's Avatar
You need to pull the door panel off, vent window, window felt and loosen the window track to get access to the regulator. Be careful if you have nice paint taking out the vent window. I would strongly recommend trying to salvage your original gm regulator. I purchased a aftermarket drivers side regulator for my 81 and it was stiff from day one and eventually got so stiff the rod coming out where the window crank attached broke free and loosened up. (my original regulator was totally seized up). I got one from a salvage yard cleaned up the mechanisms re lubed it and it works great. The key is keeping everything clean and well lubed including the track where the rollers slide. Before tightening any of the bolts for the regulator make sure the window operates smoothly. Also take pictures of how everything goes before taking anything off so you don't get confused. Good luck.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 02-09-2019, 09:39 AM   #4
TKCR
TKCR's Avatar
The one job I never took photos of for some reason. I did mine during the winter, several years back, when the truck was garaged. Watch some YouTube videos, this will help seeing how all the door parts come out, and going back in. Just cleanup all the parts of the old crusty grease and any rust or debris. And then regrease all the moving parts. I found that my glass had been broken at one time. Found little pieces of glass that they had missed. I also removed the latches too. I would suggest, getting all new rubber & felts. Polish up the glass while it is out.
Since I had every thing out of the door, I sent the vent windows away to Precision and them rebuilt. Everything else, I did myself.
Old 02-21-2019, 11:45 PM   #5
jbristo67
jbristo67's Avatar
Honestly this is one job I would gladly pay to have done as I do have nice paint. My go by Jason hills and see if he’s interested
2011 Nissan Armada
Old 02-25-2019, 08:44 AM   #6
chrismoore701
chrismoore701's Avatar
Its not that terrible. I rebuilt my wing windows and one regulator and replaced all my felt and rubber. Turned out great. Recommend having some spare parts. Regulators are year specific. I had to cut a wheel off one and weld it to mine. not to big of a deal. Good luck
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
