Old 02-08-2019, 10:19 PM   #1
BIG ORANGE
BIG ORANGE's Avatar
3 inch drop?
Wanna lower my 91 regular cab 2wd I just purchased, I figure I will buy 3 inch drop spindles, but what's the cheapest way to acquire a 3 inch drop in the rear.
I'm running 255/70/15 front and rear 8 inch rally's.
Thanxs
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 02-09-2019, 08:12 AM   #2
Stormin08
Stormin08's Avatar
Re: 3 inch drop?
probably a shackle drop
Stormin08 is offline   Reply With Quote
Old 02-09-2019, 10:50 AM   #3
Kudzupatch
Kudzupatch's Avatar
Re: 3 inch drop?
I don't think you can run 15"wheels with 3" spindles? I think you will have interference issues and I am sure the bottom of suspention will be below the wheel. So if you have a flat your going to be riding on the suspension instead of the wheel. That could be very dangerous at speed.
At the rear, do some measuring as to how much travel you have between the frame and bump stops and how much you will have after lowering it.
My experience is with a Suburban so different frame but trust me you do not want it to be bottoming out on the frame at highway speeds. It is like slamming into something solid. Shakes the whole car very hard. You may need to install a frame notch when you lower it.
My suburban was lowered when I bought it and rode really good. But out on the highway if you hit a big bump it would bottom out and it was felt like it going to break something. So I had to go back in and fix some issues.
Kudzupatch is offline   Reply With Quote
Old 02-09-2019, 09:58 PM   #4
BIG ORANGE
BIG ORANGE's Avatar
Re: 3 inch drop?
For now might just gets 3 inch springs for the front, I have the shackles and will buy the 2 inch drop hangers for rear springs.
Thanxs
Old 02-11-2019, 07:40 PM   #5
Tom
driving is in my blood
Tom's Avatar
Re: 3 inch drop?
Don't know a single company that makes 3" spindles for 88-98's, 2" only.
Old 02-11-2019, 09:15 PM   #6
BIG ORANGE
BIG ORANGE's Avatar
Re: 3 inch drop?
I'm gonna just cut 1 round out of the spring with cutoff wheel
And use drop shackle and hanger kit for rear.
