11-24-2003, 05:28 AM | #1 |
Dash lights not coming on
Sometimes when i turn my lights on, my dash lights won't come on. My turn and bright indicators light up, but nothing else. And when I turn my brights on, the indicator goes off. I used to be able to remedy this problem with a little "tap" on the dash, but not anymore. Any suggestions on what to do?
Thanks in advance for any and all info. 2-Knee |
11-24-2003, 09:45 AM | #2 |
Sounds like you might have some corrosion on the printed wiring that is on the back of your cluster about the only way to get at it is to pull the whole cluster out and try cleaning it up mine was green in several places did some cleaning and now works fine.
Steve |
11-24-2003, 02:35 PM | #3 |
LED King
The main connector plug may be slightly out of placke or the wires are loose. Try wiggling the the main connector. It may also be your headlight switch or a short somewhere. Lots of wiring to check so start now!
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
11-24-2003, 04:54 PM | #4 |
Oh,you can't buy that new
I posted this exact problem 2 weeks ago about my 85. I know dashes VERY well and i have tried everything mentioned plus a few other things , like replacing the headlight switch,and mine won't come back. If you positively find the problem let me know.
my circuit and wiring are very clean and in great shape. I also reached up and made sure the connector was firmly in. Nuttin- it's real cool :-( when i turn on the 4 ways some of the gauges do a little dance for me. DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. |
11-24-2003, 05:50 PM | #5 |
does the interior light work when you turn the switch on ?
11-24-2003, 06:21 PM | #6 |
Crossy
That still sounds like a printed cicuit problem try removing the lights that go to your blinkers and see what it does. I may have one laying around I could send you if you want it. Steve |
11-24-2003, 08:10 PM | #7 |
Slots go on anything!
high beam switch?
1974 Jimmy- 5.3/4L80e/NP241 |
