Old 02-09-2019, 04:32 PM   #1
X1 JJR
Drop Spindles on 1962 C10
I am about to install some CPP 2.5" drop spindles, the CPP disc brake conversion kit was added by a previous owner so the CP4S1 spindles I have will bolt straight on.
I am comfortable doing the swap but the one question I have is, do I do anything with the torsion bars?. Do I need to back them off or just don’t touch them at all.
Thanks in advance.
X1 JJR is offline   Reply With Quote
Old 02-09-2019, 11:27 PM   #2
macs61
Re: Drop Spindles on 1962 C10
Hi i am doing a 2 1/2 inch drop myself , back off your torsion bars all the way to take tension off them. Then tighten back up with wheels back on the ground good luck.
macs61 is offline   Reply With Quote
Old 02-10-2019, 02:01 AM   #3
SkinnyG
SkinnyG's Avatar
You shouldn't have to do anything with the torsion bars - if the truck is up in the air, the bars will be as un-tensioned as they can be, and the upper arm will move up out of the way to get the spindle off the bottom ball joint.
Fret not, my good man!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 02-10-2019, 08:58 AM   #4
X1 JJR
Thanks, that’s the answer I was hoping for!
The front of the truck will be in the air when I do the swap.
Old 02-10-2019, 09:24 AM   #5
bhap
bhap's Avatar
I'd put a floor jack under the lower A arm before releasing the spindle. I just replaced a spindle on my 62 and there was still a little "torsion" left after jacking the truck and loosening the adjuster.
bhap is offline   Reply With Quote
Old 02-10-2019, 10:57 AM   #6
X1 JJR
will do - thanks
Old 02-10-2019, 01:07 PM   #7
slepysal
slepysal's Avatar
This is how I did mine.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-12-2019, 09:41 PM   #8
X1 JJR
All, thanks for the advice. Installed the drop spindles this afternoon - very straight forward. Hopefully get the rear done by the weekend.
Old 02-12-2019, 11:07 PM   #9
bhap
bhap's Avatar
Looks good! What size wheels and tires? Any rubbing? Is that just the drop spindles or did you relax the torsion bars when you tightened them? I had to check the garage to make sure my black 62 was still in there..
Old 02-13-2019, 08:52 AM   #10
X1 JJR
Thanks, the wheels and tires are 275x60r17.
I haven’t driven it yet so not sure on the rubbing. I want to finish dropping the rear before I drive it, but will let you know then if there are any rubbing issues.
I have only used the drop spindles to lower it, I didn’t touch the torsion bars at all. Are you looking to do the same? I assume your 62 was in your garage...
Old 02-15-2019, 09:23 AM   #11
X1 JJR
I have the rear coils in and everything back together (no rubbing issues). The rear passenger side feels rock hard with no give, the rear driver side is a bit better. My first thought is that the shock absorber is bottoming out. I re-used the existing shocks as I was advised that I would only need shorter shocks if I went 4” or lower. Would it be the shocks or something else? Also rear passenger side is sitting about ¾ “ higher than the rear driver side. Would that be as a result of the issue with the shocks?
Finally, the steering feels different. Is that normal? I think it probably needs an alignment. Any recommendations / advice would be appreciated.
Old 02-15-2019, 11:46 AM   #12
SkinnyG
SkinnyG's Avatar
The steering will feel slightly different, not always for the better.
For sure spindles will affect the front roll center height, closer to the ground which should be good, but also closer to the center of gravity which should also be good.
To actually fit the tie rods with a relocated wheel, some manufacturers move the steering arm inboard to avoid hitting the wheel. This would make Ackerman worse (toe-out-on-turns), and may result in a larger turning radius. Some manufacturers move the wheel further outboard, which would increase scrub, changing steering effort.
If the back was lowered more than the front, that would increase the Caster angle on the front, making steering a bit stiffer, but should result in a better steering "feel."
The big advantage of spindles is it does not ruin your bumpsteer or camber curve like cutting springs or dropped control arms does.
Old 02-15-2019, 12:36 PM   #13
X1 JJR
Thanks, turning bradius feels good, there is slight pulling to the right when driving in a straight line so I will get the allignment done.
I was doing a bit more reseach on the rear and found some info on shock relocation kits, although these only seem to be available for 63-72 models. Would I need those or just drop shocks or both?
Old 02-15-2019, 10:45 PM   #14
SkinnyG
SkinnyG's Avatar
That I don't know, but i'm sure someone will chime in.
I've always gone through the Monroe catalog of raw data and found a compressed length that works from a comparably sprung vehicle.
Old 02-18-2019, 06:57 PM   #15
LVPhotos
LVPhotos's Avatar
I used 2wd shock mounts with welded nuts. The arms are Poterter built. But you can just move shocks fwd on top for a better angle.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-19-2019, 10:49 AM   #16
X1 JJR
Thanks. I have ordered some drop shocks, so will fit them first and see what the next step will be. I was hoping for a bolt on application rather than welding, but if that’s what I need to do, then I will have someone weld for me. Where did you get those shock mounts?
Old 02-19-2019, 11:07 AM   #17
LVPhotos
LVPhotos's Avatar
They are just nuts welded to frame.
