Old 02-09-2019, 09:03 PM   #1
marmst64
marmst64's Avatar
1964-66 instrument gauges overlay decal kit
i read several months ago that someone used to make instrument panel gauges overlay decal kit. I tried to contact the business of 60-66 Truck Shop Gauge cluster restoration decals in California with no luck http://www.60thru66chevytrucks.com/services.html
Don't know if they are out of business or not. what i'm really trying to find is 2 ea vacuum gauge decals. If anybody know who still makes these decals any help would be appreciated
marmst64 is offline   Reply With Quote
Old 02-09-2019, 10:44 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 1964-66 instrument gauges overlay decal kit
You might ask PGSigns he makes stuff - http://67-72chevytrucks.com/vboard/s...&postcount=140
He's not answering the phone number? - http://www.60thru66chevytrucks.com/contact.html
Old 02-09-2019, 10:51 PM   #3
marmst64
marmst64's Avatar
Thanks for the info I have tried 2 different guys that used to make the overlay kit both of them have quit producing them.I did try calling 60-66 Truck Shop in California for the past 2 days but got no answer.
Old 02-10-2019, 05:59 AM   #4
The Rocknrod
Moderator
It would seem that Hot Rod Magazine did an article on it - https://www.hotrod.com/articles/c10-...ith-lmc-truck/
Looks like LMC sells them - http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=53
Old 02-10-2019, 08:25 AM   #5
marmst64
marmst64's Avatar
Yes sir thanks LMC does sell them. 60-63 item number 36-9710 cost 39.95.
64-66 item number 36-9712 cost 39.95.Thanks for your help. Here are a couple of threads that have been around for sometime that will help someone restoring Instrument panel or adding gauges.
http://67-72chevytrucks.com/vboard/s...d.php?t=602504
http://www.67-72chevytrucks.com/vboa....php?p=5806390
Old 02-10-2019, 07:58 PM   #6
roll_the_dice
roll_the_dice's Avatar
I bought mine from LMC when I restored my gauge cluster...doing another cluster for a friend now. The decals from LMC work very well. I used the 2nd link you gave for restoring the cluster as a guide. Awesome thread!
roll_the_dice is offline   Reply With Quote
Old 02-10-2019, 10:49 PM   #7
marmst64
marmst64's Avatar
Great job on the instrument panel. My panel is the same as yours right now i have the tach installed next just waiting to install vacuum gage using the same procedure in the above post the first link. The original vacuum gages are getting harder to find so i bought the oldsmobile 442 gage which will work perfect with some modification.
