Old 02-10-2019, 01:30 AM   #1
68 Donkey
Push button start
Has anyone installed push button start on their C10 with LS3 swap ? If so what brand did you use and how do you like it?
68 Donkey is offline   Reply With Quote
Old 02-10-2019, 10:52 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Push button start
I think quite a few have. Here is one thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=716116
If you type "push button start" into the google search box at the top of this page, click on the circle in front of 67-72chevytrucks.com, and click the Google button you will find quite a few threads on the subject.....
LockDoc
Leon
Old 02-11-2019, 12:54 PM   #3
Mike (Asheville)
Mike (Asheville)'s Avatar
This is what I installed in my 63 Corvette, which also has a dashboard ignition switch. It uses RFID, so you just need to have the key in your pocket. I opted for the red Honda start button, which didn't cost $200 at the time.
https://www.digitalguarddawg.com/key...motive/pbs-ii/
Mike (Asheville) is offline   Reply With Quote
Old 02-11-2019, 01:23 PM   #4
weq92f
weq92f's Avatar
I have a dummy pull start switch in mine. It's not smart and is hot all the time
With this system you have, is the button smart at all? By that I mean... If you just quickly push and release the button does it crank the flywheel until the engine busts over and is running or does it just crank as long as the button completes the circuit?
My DD has a smart button. Once the circuit is made, it doesn't matter what the driver does with the button, release or hold, the computer is going to either start the engine or give up the attempt when it figures out the engine isn't going to start.
I am looking for a replacement for my current setup ( pull switch ) whether it be a button like you guys are discussing or going back to a key switch.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-18-2019, 11:14 PM   #5
Sparky dave
I put remote start on mine on a key fob for £17 on ebay
Sparky dave is offline   Reply With Quote
