![]() Join Date: Jul 2018
Brake pushrod to short can I swap?
Working on a 1970 3/4 ton I ordered a brake booster from Napa part #54-71011
I am installing it now and the pushrod is 1-1/2” shorter so I can’t bolt it up to the pedal. Can I swap these out? Doesn’t seem to pull out? Don’t want to damage the new one if I have to bring it back. I looked up 1ton part number and it is the same? Any help would be appreciated Trip |
![]() Join Date: Oct 2009
Re: Brake pushrod to short can I swap?
Have you tried hooking up the vac source and starting the engine - not sure but that may move it toward where you need it.
Moderator
![]() Join Date: Jun 2017
The rear brake booster shaft is not replaceable unless during a major overhaul...
I have seen this before... Check out https://www.napaonline.com/en/p/NBB5473709 Call the NAPA store, check their stock then take your old one to match the length..... Have fun... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
Yes that looks like my old one, I will order it tomorrow
Thanks for the link! Trip |
