Old 02-10-2019, 01:33 PM   #1
dracko
dracko's Avatar
1964 fender badge hole location
Getting my 1964 c10 painted next weekend and almost forgot to drill the fender badge holes. I searched around and checked the service manual but can’t find measurements on where to drill them. Any info would be appreciated.
dracko is offline   Reply With Quote
Old 02-10-2019, 02:23 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 1964 fender badge hole location
Found this - http://67-72chevytrucks.com/vboard/s...d.php?t=459944
Old 02-10-2019, 03:07 PM   #3
dracko
dracko's Avatar
Originally Posted by The Rocknrod View Post
Thanks but that is for a 63. Holes the same?
Old 02-10-2019, 03:26 PM   #4
The Rocknrod
Moderator
Sorry about that I dint realize. I guess I could go out and measure...
Old 02-10-2019, 03:49 PM   #5
The Rocknrod
Moderator
Your not gonna like this. On one fender I got 6-3/4" from the rear edge of the door, one the other 6-5/8". Center of hole.
From the top - I stuck a credit card (and held it downward pressure) between the cowl and the fender to get the top dimension to the top hole - 4-3/4". Center of hole.
2-3/4" between holes center line.
Hope this helps. I'm not the sharpest knife in the drawer around this forum so...
Old 02-10-2019, 04:00 PM   #6
TopFuel1966
TopFuel1966's Avatar
If you know for sure that they are '64 fenders you could probably find where the holes were filled if you looked at the back side of the fender. You might have to scrape off some crud, paint, undercoating, etc.
TopFuel1966 is offline   Reply With Quote
Old 02-10-2019, 05:31 PM   #7
dracko
dracko's Avatar
Right on that is a big help, did you mean rear edge of fender? Also, was the top hole an 1/8” further ? And for the height part... I’m sorry I’m also not the sharpest knife, but you had the credit card sticking straight out and then measures 4 3-4” down? Or flat flexing on the fender ? thanks very much for the help.
Old 02-10-2019, 05:32 PM   #8
dracko
dracko's Avatar
That would be cool but these are salvaged fenders from random years
Old 02-11-2019, 03:05 AM   #9
dracko
dracko's Avatar
I managed to get ahold of a ‘64 fender for measuring.
Like RocknRod mentioned, 6 5/8” from edge to center of holes. For the other measurement I used a fabric tape measure laid flat on the fender from the top butted up to the upper mount. Higher hole is 6 3/16” down and the other is 8 15/16” on center. Hopefully this info is of some use to someone down the road. ✌️
Old 02-11-2019, 07:30 AM   #10
The Rocknrod
Moderator
Mine is mounted on the truck with the cowl installed so I measured it differently from the top.
