Old 02-11-2019, 01:19 PM   #1
GreyFox
Chevy S10 T5 WC Transmission in a '65 C20
Has anyone done a T5 update and install of the T5 transmission in a 60-66 truck and have you put miles on it and have good experience driving it on a 2WD truck?
Swap info here:http://67-72chevytrucks.com/vboard/s....php?p=4871869
My goal with my project is to keep my C20 a 3/4 ton rated truck but have better driving on the freeway. I'm thinking about keeping my full floating Eaton axle (Converted to a '72 4:10 ratio for 2WD truck) and swapping out the transmission instead of swapping the axle out to a Dana 70 or something like that.
Would the T5 handle towing? Or do I keep the SM420 or go to SM465 and swap out the rear axle?
GreyFox is offline   Reply With Quote
Old 02-11-2019, 01:32 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Chevy S10 T5 WC Transmission in a '65 C20
Another FAQ section question - http://67-72chevytrucks.com/vboard/s...d.php?t=646002
T5 swaps - http://67-72chevytrucks.com/vboard/s....php?p=4871869
http://67-72chevytrucks.com/vboard/s...d.php?t=607402
Member Lugnutz has a bunch of info on it - https://www.google.com/search?domain...D%3A1%3B&hl=en
Old 02-11-2019, 01:33 PM   #3
LVPhotos
LVPhotos's Avatar
T5 is not rated for trucks. The aluminum case will twist under load. Original tq is 400 or so go tko 500 or 600
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-11-2019, 03:35 PM   #4
GreyFox
Understood - Yes I would not want to have a transmission detonate under me while driving...
I wonder if the overdrive units out there for the sm465 are worth the trouble then since they are aluminum.
Understand I'm new at this and trying to make something workable if possible.
Old 02-11-2019, 06:19 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Here's what I did as an alternative to a T5 swap. Based on info, the AX15 is stronger than a GM T5. I don't have the truck I did this too anymore but I put several thousand miles and the guy who bought it from me did more.
I liked it enough I have another one sitting in my garage for my panel truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=475370
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
