Urgent! Modern Paint Code Needed for Turquoise Poly 510 Metallic
Well I made the mistake of assuming paint code 510 Turquoise Poly wouldn’t be an issue to have mixed up in waterborne paint (Axalta), that is not the case.
Painter sprayed a test card and it’s no looking like a match. If anybody has had a paint color like this sprayed recently please feel free to share the paint code used. ![]() ![]() Last edited by dracko; 02-15-2019 at 12:02 AM. |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Modern Paint Code Needed for Turquoise Poly 510 Metallic
Hey RocknRod thanks, I did reference that site for the WA5123 code that my painter used to mix. But this is the color it turned out as.
![]() ![]() So I’m looking for other paint codes folks may have used to achieve an accurate Turquoise Poly. I’m gonna head down there tmrw and look through color chips as well. |
Moderator
I saw a 62 Impala (my dream car) recently that color, made me want to paint my truck with that as the base color still using my cream. Great color.
![]() Join Date: Aug 2010
#7 | |
![]() ![]() Hard to believe his burb and your truck are the same color. The burb looks closer to Tampico Turquoise but is indeed a 510 truck. |
Lighting has a lot to do with the difference on metallics. A good example is the shot below where the trucks are lined up. The 65 Suburban and 66 C10 are both turquoise. Some age fading and a little direct sunlight on the Burb makes it look like a different color entirely.
Looks like GM had 2 variations of 510. 1963 it was Crystal Turquoise and looks much more blue. Gonna have painter spray a card and see how that looks.
[URL=http://s284.photobucket.com/user/drackett19/media/9DB6690F-2341-4175-A9E8-33C5506432ED_zpsfewfgnnn.png.html] ![]() Last edited by dracko; 02-15-2019 at 12:00 AM. |
If anybody has any turquoise paint code they can share it’d mean a lot. I’m running out of time before scheduled paint.
![]() Join Date: Dec 2009
My paint Guy is still work on my 510 Turquoise paint. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Paint Code OEM 510(Crystal Turquoise, Metallic) is PPG 43276. I had them mix a single stage spray can to "test", and then went for it. LIGHTING makes a huge difference in the color appearance. It is a beautiful color
Jake Old fart in Western NE |
#13 |
Wow that actually is beautiful. Do you have any more pics? The pics I saw looked very very green.
#14 |
The other code I have is WA5123. Here are some other pics. These are all inside at the painters. Will try to get some in the sun. Just have the tailgate done right now. Wanted to make sure it was what i wanted. IT IS !
#15 |
Thanks again for the pics and info Jake. I ended up going with the PPG 43276. I’m looking forward to seeing it done.
#16 | |
Sweet ! Post pics, lots of pics !!
#17 |
#18 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Absolutely Spectacular!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#19 |
nice!!
#20 |
#21 |
That looks Great.
![]() I am going to my paint shop Guy with that Paint number.
#22 |
![]() Join Date: Jun 2015
Looks great! Where did you get it done?
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
#23 |
#24 |
Beautiful! Hope it looks as good in person. Great color!
#25 |
Awesome ! Glad it worked out for you. I'll send you the paint code for the "vanilla" we used on the tailgate. Nice to see what mine will look like someday !
