Old 11-24-2003, 01:38 PM   #1
maineiac
Tranny Question
I am going to replace my 700r4 boat anchor with a turbo 350 and was wondering what kind of kickdown they use? Is it a cable? vaucum? electric what?
Thanks in advance
Steve
maineiac is offline   Reply With Quote
Old 11-24-2003, 01:49 PM   #2
Jonboy
Slots go on anything!
they use vacuum to shift, and have a kickdown cable. There will need to be a tee put in the port behind the carbuerator, to go to the vacuum modulator.
Why don't you like your 700? It is a better trans, if it is in good working order.
BTW, you will need to lengthen the driveshaft and change the front yoke for the 350.
1974 Jimmy- 5.3/4L80e/NP241
Old 11-24-2003, 02:42 PM   #3
maineiac
I am getting a 350 that is the same length as my 700 the reason I am swapping is the 700 lunched itself yesterday and just can't swing the cost. I thought the yokes were the same on 350 and 700 are you sure they are different? BTW it is an early model 700.
Steve
Old 11-24-2003, 02:53 PM   #4
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Why on earth would you want to go to a TH350 rather than a 700?
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 11-24-2003, 06:18 PM   #5
maineiac
Cost and reliability
Old 11-24-2003, 06:40 PM   #6
Jonboy
I am pretty sure the 700 uses a 400 style yoke. You might want to check and make sure. You may have to move the trans crossmember forward a little, but the holes should be in the frame for it.
Old 11-24-2003, 07:36 PM   #7
arveetek
Ultimate Diesel Dude
arveetek's Avatar
700R4 and TH350 use the same driveshaft yoke.
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's
Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's
arveetek is offline   Reply With Quote
Old 11-24-2003, 07:41 PM   #8
86SILVERADO
86SILVERADO's Avatar
casey is right. You will have no problems switching the two as there is not enough difference in length and the splines are the same. You will have to move the crossmember to the rear a bit but the bolt hole are there in the frame already. You also have to hook it up to manifold vacuum as jonboy said.
You will have to move it forward like jonboy said. The 700 and 350 trans does not have the bolt in yoke like the 400 you just drop the driveshaft and slide the shaft off the trans. If you have it up on ramps make sure you have a drain pan behind the tailshaft when you do this, make sure you are not laying directly underneath it either.
I will never forget the first time my less than mechanically inclined buddy tried to change his oil. I actually convinced him to do it and told him how but I forgot to tell him not to lay directly under it. I just heard him yell loud enough to wake the dead and he came rolling out of there with his face covered in oil he even got it in his mouth, down his shirt, everywhere, luckily it was not too hot. I had to try so hard to keep from laughing but he probably would have killed me if I had.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 11-25-2003, 10:13 AM   #9
maineiac
Thanks for all the help I have found a local guy here who will build me a 350 with lockup that should hold up to my 350 no problem and best of all its only 600 instead of the 1100 I can find a 700 for. Thanks again I will keep you posted all I have to do know is find the time to get the dam thing out and get him some money to start building the new one. can you guess what I am doing on thanksgiving?
Later
Steve
Old 11-25-2003, 12:22 PM   #10
Low87
been here longer than Liz
Low87's Avatar
$1100! Damn! I had my 700R4 rebuilt a few years ago for $550.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 11-26-2003, 10:49 AM   #11
maineiac
Aint inflation great? I can get one from Bowtie Overdrives for 900 but after shipping and the hassel of dealing I decided to go local well North Carolina anyway jackson Racing has good prices on their 350's and will take my 700 as a core.
Steve
Old 11-26-2003, 11:40 AM   #12
Destructo
Good used 700r4's go for 450 bucks locally here, and to get one rebuilt your looking at 1200-1500 dollars. I just rebuilt mine myself after calling around. Cost me about 300-400 bucks and I have a like new transmission that has been running strong for 2k miles and shows no signs of slowing down.
Destructo is offline   Reply With Quote
Old 11-26-2003, 02:41 PM   #13
maineiac
About the same here I just have not tackled a 700 before and I am quite sure I broke something major inside it went out with a bang then nothing but reverse.
Steve
