02-13-2019, 02:45 AM | #1 |
Brake Lines
I tried using Google to get an answer but no luck...is there any reason I cannot just AN Brake lines throughout my truck instead of having to bend steel and flaring for fittings? SS hardline is just as expensive...
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
02-13-2019, 03:21 AM | #2 |
Re: Brake Lines
You can run stainless steel flex lines throughout, but make sure they have Teflon inners. The Teflon tube doesn’t expand with pressure, is unaffected by brake fluid or temperature, and has little deterioration with age.
I ran flex line from the master cylinder to the four corners in my road race car years ago and never had any issues. But it’s not cheap.
Customization is what you want it to look like -- not what other people think it should look like |
02-13-2019, 05:26 AM | #3 |
Post Whore
Re: Brake Lines
no reason you cant...but the premade hard brake lines like oreillys sells are pretty inexpensive...you can piece them together...they have all different lengths...that's how I did mine ..but I also have the flare tool so I could cut long pieces to exact lengths...
02-13-2019, 08:52 AM | #4 |
Re: Brake Lines
buy a pre-bent kit for your year/model and save yourself the headache of making your own its not that bad of a price when compared to pricing out all the proper rated flex line and fittings
02-14-2019, 11:32 AM | #5 |
meowMEOWmeowMEOW
Re: Brake Lines
Nickel copper brake line is my answer to all brake line questions. Looks better, bends better, flares like a boss, and lasts way longer. Also its gold so I like it.
....it is 4x as expensive as regular line tho.
02-17-2019, 03:26 AM | #6 |
Re: Brake Lines
I do commercial sales for O'Reilly's so...my discount lets me do what ever I want. Most behind the counter stuff can get up to 70% off. Plus I can buy from the Jobber side of Summit.
02-22-2019, 08:13 AM | #7 |
Re: Brake Lines
I second the nickel copper. For the hard line parts its the best stuff and then run the braided from the frame to the axle and calipers. When you make up your braided lines have them hydro tested. We did this on all the drag cars and had one fail hydro. Thats the best time for one to have a problem.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
