Old 02-13-2019, 01:33 PM   #1
dfosh
Power steering pump
I am trying to mount the power steering pump and I am having problems . I have the stock cast bracket with the steel plate that has the adjustable slot and mounts to motor mount. I have one stud on the back of the pump that the bottom bracket mounts to. Should their be another stud for the adjusting slot? Can some one post a pic of how the brackets fit on the pump ? This is for 71 sbc .Thanks
dfosh is offline   Reply With Quote
Old 02-13-2019, 01:47 PM   #2
kazoocruiser
Re: Power steering pump
It would help if you would post pictures of what you are working with.
Lots of pictures.
1981 C-10 Longbed, 250 (4.1) 2bbl Varajet, THM-350C.
Some of the Build progress:
https://www.youtube.com/channel/UC_W...foLyeDq_WQPNmA
1981 Harley Davidson.
Credentialed, semi-retired A.S.E. technician. If you don't like free advice, Ask Someone Else and pay for it.
kazoocruiser is offline   Reply With Quote
Old 02-13-2019, 03:05 PM   #3
tim71
tim71's Avatar
Here are some pictures of the back side of my power steering pump. Maybe this will help. The pump pivots off the lower bolt.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 02-13-2019, 03:14 PM   #4
dfosh
Tanks for the pic . My pump just has the bottom stud . It does not have one for the upper slot in the bracket. I guess ill have to fab something up.
Old 02-13-2019, 05:01 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The bottom pivot fastener isn't a stud. It's a long bolt that goes through the pump body and bracket and held with a "pinch" nut, or a nut with a lock washer. The only stud on the back of the pump goes through the adjusting slot. I have the exact same setup on my 1972 GMC C15 with a 350.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
