What Trans Dipstick and Tube?
Guys,
What are you using for the transmission dipstick and tube for a 65 5.3 with a 4l60e? Thanks |
Re: What Trans Dipstick and Tube?
I'm planning to use the one I got from the transmission's donor, a 2008 1500 Silverado. I haven't mounted the cab yet though but wasn't anticipating any problems.
Post Whore
![]() ![]() Join Date: May 2015
Yeah I was just wondering what's wrong with the stock one......is it a clearance issue?
![]() Join Date: Jun 2015
When I got my motor and trans (2003 Tahoe, 5.3 Flex, 4L60E) the dipstick tube had been broken at the mounting tab that goes under the transmission bolt. I got a new one from a GM dealer and used the original dip stick.
It has cleared the cab and A/C unit on my 85 C10 with no issue.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
Thanks guys, I don't have one and was wondering what worked on the 60-66 models.
meowMEOWmeowMEOW
I've had the regular truck version and the van version. Same thing just the length difference. The truck version hides away a bit, the van version is easier to check without leaning over all the way, but sticks out over the passenger side a bit.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I used an fbody, it puts the handle tight to the passenger side of the motor.
Can you see the red handle??
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 02-15-2019 at 09:54 PM. |
When you do get a dipstick it should read full when the fluid is even with the pan gasket.
