02-15-2019, 08:54 AM | #1 |
1957 Clutch & Clutch Pedal Help/Advice
I'm working on my wife's 57 pickup and I would like to convert it to a manual transmission. Right now, I'm using the CPP frame mounted brake system with the pedal bracket, booster and master cylinder. The truck will have 4 wheel disk brakes.
I already have the T5 and clutch disk but am not sure what I would need as far as pedal and linkages. Will stock/original parts work with what I currently have? Am I better off mounting everything on the firewall and using an under-dash bracket? I am open to a mechanical or hydraulic clutch. This is her truck and I want it to be reliable and easy to maintain. Pictures of current setups would be alot of help. Thanks to everyone for your advice/assistance in advance.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
02-15-2019, 01:11 PM | #2 |
Re: 1957 Clutch & Clutch Pedal Help/Advice
what kind of bell housing are you using? Should be pretty easy to find the stock clutch parts .
02-15-2019, 04:22 PM | #3 |
Based on the original posters ....T5 transmission, 4-wheel disc brakes.... I would hazard a guess that this truck is no longer stock and will require all aftermarket parts. The stock clutch pedal may be re-usable, but I am outside my knowledge base on how to get a stock clutch pedal to work with a T5 transmission. Perhaps a member with experience making a resto-mod will reply.
My Build Thread http://s95.photobucket.com/user/drop...?sort=3&page=1 |
02-15-2019, 06:35 PM | #4 |
Hello LDO. Just a couple of pictures showing what the stock parts look like. This is with a stock bellhousing in the stock location. Also using the T-5
transmission. This is all I can offer you. Good luck. Earl
You have to have patiences or you'll be one. |
02-15-2019, 10:16 PM | #5 |
Post Whore
Somewhere in his build, old57 has a aftermarket pedal setup in his
02-16-2019, 10:55 AM | #6 |
I do not have a bellhousing as of yet. I would assume a stock bellhousing for a SBC.
02-16-2019, 10:56 AM | #7 | |
Thanks for the pics, they help alot.
02-26-2019, 08:46 AM | #8 |
I am missing the clutch pedal frame bracket. All I have is a hole in my frame.
02-26-2019, 09:17 AM | #9 |
02-26-2019, 10:23 AM | #10 | |
I already contacted him, he does not have the frame bracket.
02-27-2019, 07:04 PM | #11 |
This place has a few GMC's and Chevy's he might have what you seek
https://www.dvap.com/?s=any&q_make=G...&submit=Search |
