Old 02-15-2019, 09:35 PM   #1
clay68c10
clay68c10's Avatar
Motorhome Tilt Column
$250 shipped in lower 48
Please respond in thread only per board rules, first "I'll take it" gets it.
Selling a motor home tilt column. From an early 80s GM chassis
Move the NSS down and it's a bolt-in for your 67-72. There's some threads about this mod.
Tilt mechanism is tight.
The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight.
Tilt pivots were cleaned and lubed when removed to tighten the bolts.
The bottom bearing was greased and is in good shape.
The shift indicator bulb was replaced and tested OK, it has the green shade on it.
Shifter arm end (inside column) is good, pivot is average
Turn signal and tilt levers are driver quality
Turn signal switch is tight and cancels as it should
Turn signal has the flat connector
The gray illumination wire is long enough to be spliced well under the dash
Includes a long pigtail for the Neutral Safety/Reverse switch
This column is good for a driver, it's clean but has some scratches and normal wear
It would be a great candidate for a scuff and shoot if you wanted to make it really nice.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-15-2019, 09:38 PM   #2
clay68c10
clay68c10's Avatar
Re: Motorhome Tilt Column
Pics
13 Tahoe LTZ
Old 02-15-2019, 09:43 PM   #3
clay68c10
clay68c10's Avatar
More pics
13 Tahoe LTZ
Old 02-16-2019, 05:30 PM   #4
clay68c10
clay68c10's Avatar
Saturday bump
13 Tahoe LTZ
Old 02-20-2019, 04:57 PM   #5
clay68c10
clay68c10's Avatar
Ttt
13 Tahoe LTZ
Old 02-22-2019, 06:08 AM   #6
OL SKOOL
OL SKOOL's Avatar
I can't believe no one has grabbed this yet great deal. I just bought one before Christmas that cost more . Mine was pulled out of a shed and then I had to go through it. Fit just like a factory tilt and only takes about 30 min to move the neutral switch. I will tell my buddy about it should fit a 65 also?
OL SKOOL is offline   Reply With Quote
Old 02-22-2019, 07:31 AM   #7
clay68c10
clay68c10's Avatar
I suspect it will fit the 60-66 trucks, but I haven’t messed with one in years so I don’t know.
13 Tahoe LTZ
Old 02-24-2019, 05:09 PM   #8
short n wide 72
short n wide 72's Avatar
Would you take $225 shipped?
short n wide 72 is offline   Reply With Quote
Old 02-24-2019, 09:47 PM   #9
clay68c10
clay68c10's Avatar
I can meet you in the middle at $235, shipping is high for these.
13 Tahoe LTZ
Old 02-25-2019, 12:20 AM   #10
short n wide 72
I'll take it.
Old 02-25-2019, 09:07 AM   #11
clay68c10
clay68c10's Avatar
Sold to short n wide 72
13 Tahoe LTZ
Old 03-01-2019, 10:27 PM   #12
short n wide 72
Got it.
Thank You
