Old 02-17-2019, 12:03 AM   #1
TruDom
need help finding this bolt - bench seat
this bolt/screw mounts the back of the bench seat to the bottom seat.
need to buy 2 and can't seem to find any thing close to it. have struck out at hardware stores and lmc etc.
TruDom is offline   Reply With Quote
Old 02-17-2019, 08:59 AM   #2
Sheepdip
Sheepdip's Avatar
Re: need help finding this bolt - bench seat
https://www.mcmaster.com/standard-flat-head-screws
Sheepdip is offline   Reply With Quote
Old 02-17-2019, 09:45 AM   #3
Smitty
Smitty's Avatar
Try www.topecoproducts.com. They carry a large number of automotive fasteners not available elsewhere.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 02-17-2019, 12:10 PM   #4
jaros44sr
jaros44sr's Avatar
That looks alot like the screw on my Jimmy that holds the heater control panel to my dash
I thought mounting bolts for the seat were hex head, can't imagine the trouble you would have if the phillips head were to strip out
[url=https://flic.kr/p/2dptZxP]20190217_111119
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-17-2019, 12:59 PM   #5
chiefcfd
chiefcfd's Avatar
Let me look when I go out to the shop later. I may have some. I don't know for sure.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 02-17-2019, 02:25 PM   #6
chiefcfd
chiefcfd's Avatar
I just looked out in the shop. I could not find that screw. I have just about everything else but that one. Sorry I couldn't help.
Old 02-17-2019, 02:56 PM   #7
72c20customcamper
72c20customcamper's Avatar
The bolt is to hold the seat back to the bottom. Two on each side.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 02-17-2019, 03:26 PM   #8
Red71gmc
I remember those when I recovered my seat. Two of mine had the Phillips stripped pretty bad but I was able to salvage and reuse. General hardware store should have one only without the taper to help start it in the hole. If not the above mentioned place probably will.
Red71gmc is offline   Reply With Quote
Old 02-17-2019, 03:32 PM   #9
jaros44sr
jaros44sr's Avatar
OK, misunderstood post
SAFETY FIRST
AS usual, off topic
Jim
Old 02-18-2019, 06:35 PM   #10
bill3rail
bill3rail's Avatar
Specialty Retail on the parts board!
Manes Truck Parts!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 02-18-2019, 08:58 PM   #11
rcazwillis
I replaced all four at an Ace hardware. Not factory, as it was a hex head vs philips. Did not matter to us as it was covered up by the seat upholstery.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 02-23-2019, 08:35 PM   #12
jcwren
Not sure if it's the same size, but that looks to be the same style as the three screws that holds the door latch assembly to edge of the door. Item #7 on page 23 of the latest LMC catalog.
1970 C10 LWB Stepside
1971 Dodge Dart
1993 Buick Roadmaster Estate Wagon
jcwren is offline   Reply With Quote
