02-17-2019, 12:06 PM | #1 |
Before and After
72 parking brake hardware. Pic included
I am looking for this specific piece from the brake hardware. I think I can make it if I knew exactly what it looks like.
Would anyone have one they could take a couple of photos for me. It is the part that goes on to the solid rod through the frame to tension the cable.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
02-17-2019, 01:36 PM | #2 |
Re: 72 parking brake hardware. Pic included
I think this would be it.
http://sokyclassics.com/product.php?...08c534090a1395 It’s the same as #9 in the diagram. |
02-17-2019, 07:15 PM | #3 |
Before and After
Geezer#99,
It is the same as #9. Although I do not need that item. I’m looking for tha part that goes on the rod, not the brake cable.
02-17-2019, 08:05 PM | #4 |
Yes think you will be able to make it as it’s only folded tin it hooks over the cable and is a tight fit so the cable can’t fall out I’ll take a picture of it tomorrow if no one beats me too it
02-17-2019, 08:09 PM | #5 |
It’s called a parking brake equaliser apparently here is a pic I found for you on google images
02-18-2019, 12:05 PM | #6 | |
Before and After
I’m trying to figure out how it holds the cable when it is loose, and yet stays on t the rod at the same time.
02-18-2019, 12:24 PM | #7 |
Did you try Scott at Scott's Super Truck's in Penhold Alberta just south of Reddeer ?
Darren
1967 C10 Shortbox 1971 Monte Carlo SS buckets and console #'s car 1970 350 Monte Carlo bench seat 1970 El Camino SS |
02-18-2019, 12:49 PM | #8 |
Here's a pic that shows both of the clips -- The rod goes through the clip, above the cable. The other end of the rod connects to the frame. Note that the clip is curved slightly to allow the cable to move freely
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 Last edited by dfwright; 02-18-2019 at 01:07 PM. |
02-18-2019, 05:20 PM | #9 |
https://www.rockauto.com/en/moreinfo...029833&jsn=324
Rock Auto has the guides and clips for less than $17.
Stupidity was meant to be painful! |
02-21-2019, 12:57 AM | #10 |
Before and After
That’s the picture I was looking for. Thank you dfwrigh. For what it was worth, I have ordered the kit from Rock shipping to me in Canada is $19 usd. Should arrive tomorrow.
02-21-2019, 01:00 AM | #11 | |
Before and After
I previously had him send me the cable connectors. He usually has some used items kicking around.
