Old 02-17-2019, 06:01 PM   #1
Arl37
How much clearance is needed between bump stop and rear axle.
Installed 4" drop leaf springs on 69 C10. After shaving rubber bump stops I have about 1 3/4 inch clearance between bump stops and frame. Is that enough or should I C Notch?
Arl37 is offline   Reply With Quote
Old 02-17-2019, 08:25 PM   #2
Sparky dave
Re: How much clearance is needed between bump stop and rear axle.
Guess people going to tell ya that it depends on what roads your driving on and if your putting weight in the bed. Folks are running 5 inch drop and more with no c notch but these trucks all sit a little different from one another particularly the long beds sit a bit lower cause of the extra weight I think. Try it and see that’s my vote
Sparky dave is offline   Reply With Quote
Old 02-18-2019, 08:51 AM   #3
Mike C
Mike C's Avatar
Trim your bump stop in half. That will get you some more clearance. I flipped the axle on m y 69 short step and it netted just over 7” drop. I removed factory bumpstops and installed the 3/8” puck urethane pads tha came with the DJM flip. I have about the same clearance as you from axle housing to puck. With your OEM stops trimmed, you should seldomly connect.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-18-2019, 08:58 AM   #4
I know only 1", such as 6" rear coils, 'can' bottom out. I think a couple inches should be good. Doing what Mike suggested will get you there.
