02-17-2019, 06:29 PM | #1 |
1 ton 4x4 conversion
Can anyone tell me if I can convert my 1987Chevy 1 ton 2 wheel drive truck to 4 wheel drive using a 1978 drive train. I have a 3/4 ton doner.
02-17-2019, 06:32 PM | #2 |
Post Whore
Re: 1 ton 4x4 conversion
it can be done but youll need a intact 4x4 donor frame..i think the 1tons came with a dana60 front
this may help.....http://www.67-72chevytrucks.com/vboa...d.php?t=546339 http://chuckschevytruckpages.com/robsK35.html https://www.truckforum.org/threads/c...version.15456/
02-17-2019, 06:44 PM | #3 | |
02-17-2019, 07:06 PM | #4 |
c and k 30 1ton frames are bigger than 1/2 and 3/4 ton frames .
yes k30 had dana 60 front over the smaller dana 44 or corp 10 bolt axle . the best way if you want the full k30 package is find a whole roller with good frame and driveline and swap your body over . . or find a k30 and fix it up .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
02-17-2019, 07:19 PM | #5 |
Thanks for the response , it's a fire wood truck, so doesn't have to be perfect but 4 wheel drive would sure be nice!
02-17-2019, 08:09 PM | #6 |
Your mounts are different. Meaning 73-80 had different core support/cab mounts than your 81-87. If it's just a woods truck not end of the world. Front mounts swap between 1/2 up to 1 ton though. You'll run into crossmember clearance I think unless you got a good sized lift. Have to swap members, as the motor mounts differently though. I'd just.body swap, and maybe rear springs since you'll have it loaded a lot.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
02-17-2019, 08:45 PM | #7 |
If you got a welder and grinder anything is possible. Depends on whether you want form or function?
02-17-2019, 09:45 PM | #8 |
73-80 = 1 style body mount
81-up = other style and its the frame side that makes the choice of mount style . i have a k30 frame with a c-10 body and low hump floor no body lift and th400/203-205 double t-case setup and 1 tiny dent in floor pan . and had to do custom shifter boot anyway so no problem .
02-18-2019, 08:01 AM | #9 |
SWB 4x4 Collector
Front frame rails above front axle are higher up on a 4x4 frame compared to 2wd.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-18-2019, 06:45 PM | #10 |
These guys had the imho best 1 ton 4x4 conversion kits. Unfortunately they arent making them right now. You can kinda see what your in for by watching the videos on the website though.
http://cutbros.com/ |
