02-17-2019, 06:56 PM | #1 |
Need help switching from automatic to standard
I have a 72 with a 350/350 setup going to switch to 454 and a 4 speed muncie but the 454 has a flex plate and the car I'm getting the muncie from is a small block.... My question is when I get a flywheel can I have it balanced to match ? Or should I do something else?? Any suggestions is greatly appreciated..... Thanks in advance...
It's been a long time coming... It's time to get it done.. |
02-17-2019, 07:14 PM | #2 |
Re: Need help switching from automatic to standard
A 454 BBC and 400 SBC is externally balanced. 350 and the rest are internally balanced. You will have to buy a 454 specific flywheel or you will make serious balance problems. They have a large long weight cast into them. Just an fyi... The balancers are also different
1972 k10 Custom 10 Deluxe, short bed 4x4, 454, 4 speed (Sold) 1985 K30 Dump Truck 1986 Jeep CJ-7 1955 2 door 210 post |
02-21-2019, 07:00 AM | #3 |
Ok but what I am really wanting to know is can I buy a new 454 flywheel and have it balanced to match the flexplate that is on the 454 now and just switch them out or will I have to have it rebalanced with all the internals at the machine shop??? basically I just really don't want to take it apart if I don't have to....lol
02-21-2019, 09:38 AM | #4 |
You can just get the 454 flywheel and run it. The crankshaft should be drilled for the pilot bearing/bushing.
Check the bell housing casting number to see what diameter flywheel and clutch it is for and purchase accordingly.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-22-2019, 05:37 PM | #5 |
Moderator
What year model is the 454?
See this link as it has all the info you will need...just ignore the popup ads etc.... https://www.chevydiy.com/how-to-sour...nd-flexplates/ Also...wondering why you want to swap in Muncie...I think a simpler route would be a stout TH400 or a 4L80e auto...just my opinion...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
02-23-2019, 08:37 PM | #6 | |
