Bed Grounding - light issue
No lights are working in the bed. They worked two weeks ago, but not today. The power is getting to the plug. Has to be a grounding issue. How does the bed get grounded? Is frame contact the only source of grounding?
Zane's 71 Build |
Re: Bed Grounding - light issue
Here's a good thread that will help you http://67-72chevytrucks.com/vboard/s...d.php?t=422234
72 C10 lwb fleetside -stock 350/350 combo |
There is a ground strap from bed to frame and frame to battery you can check resistance with a multimeter. Or check voltage on lighting wires but try put your ground probe on the bed. If nothing try ground probe on frame and lastly use a length of wire to put your ground probe to the battery ground. This will tell you where the break in the ground path is back to the battery. Hope you can follow my descriptio, good luck
landarts
![]() Join Date: May 2005
I just went through this about a week ago. I removed the light housing, then you will see two clips that the screws go into, remove the clips, clean the metal on the bed where the clips go, if the clips are rusty clean or replace. If the housing is dirty or rusty clean that also. Reassemble and you should have better ground situation which will allow the light to work properly. This is what I did and it worked for me. My housing, bulbs, and wiring harness was brand new, but when I painted truck the clips were painted, once I cleaned the metal of paint it grounded. Good luck!
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
![]() Join Date: Sep 2015
I added a battery cable from the engine block to the frame. Then added a number 6 green stranded wire with wire lugs, at the rear of the frame to rear of bed under the truck. You can get all that at Lowes.
Picked up a grounding cable at parts store. Grounded frame to bed. Lights work...problem solved.
Zane's 71 Build |
