02-18-2019, 11:41 AM | #1 |
What are these holes?
Cleaning up around the inside of my cab on my 71 before I do the carpet kit and looked up and noticed these holes. The drive side has the plug out of the middle and the two little holes drilled out but the passenger doesn’t. What are these for? Or what could have been there on the driver side that wouldn’t be in the passenger?
02-18-2019, 11:43 AM | #2 |
Re: What are these holes?
And of course the pictures are turned...
02-18-2019, 11:57 AM | #3 |
the big holes are for over the shoulder seatbelts
02-18-2019, 11:57 AM | #4 |
mounting holes for shoulder seat belts. should be threaded already. Just pop the cap off.
02-18-2019, 01:39 PM | #5 |
Did they ever come factory in these? And would it be just one side or should both have them
02-18-2019, 02:43 PM | #6 |
The anchors were in all of the trucks but the shoulder harness was not standard. I believe it was an option. Both passenger and driver side have the anchors. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-18-2019, 02:57 PM | #7 |
I would think the spid would say if it came with them, which it does not. At least I know what they’re for
02-18-2019, 04:35 PM | #8 |
1972 Cheyenne
02-21-2019, 12:46 PM | #9 |
They were a rare factory option. People spend crazy money on them like tow hooks, even though they're a pita to use. Sure they look cool, but they're functionality sucks. Not worth the money imo
72 C10 lwb fleetside -stock 350/350 combo |
02-21-2019, 02:04 PM | #10 |
Are they tied into the lap belt like a late model? My brother's '69 Chevelle had them held up by clips on the headliner. He always just used the lapbelts.
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
02-21-2019, 02:16 PM | #11 |
Maybe Special K has seen a factory one!!!
02-21-2019, 02:29 PM | #12 |
Yes, like the Chevelle, 2 separate belts. The shoulder belt doesn't ratchet like modern belts, so once you're strapped in you're not moving anywhere. They're just a pita
02-21-2019, 04:21 PM | #13 |
Below is a picture of factory shoulder belts I found in a '72 Blazer in my local junkyard. They cost me $10. The rear belts had been cut off at the base of the boots leaving the additional parts in the center of the picture. I plan to use these parts and some lap belts to make another set of shoulder belts.
Here are a couple threads with some good info. http://67-72chevytrucks.com/vboard/s...d.php?t=455323 http://67-72chevytrucks.com/vboard/s...d.php?t=339651 |
