Bleeding brakes - one issue.....
So when I bled my brakes this summer after installing a new power brake booster setup i started with the RH rear wheel end I could not get the fluid to bleed out with many pedal pumps. All other locations seemed to work ok.
What do you guys think - would there be a blockage at the tee block on top of the difff or maybe in the brake line and if so how best to clear the blockage.... It seems as if the booster has not performed well in my opinion even after changing the front disk brake pads.... One thing i did not do is bench Bleed the master cylinder with the kit provided by CPP (Classic Performance Products ) as i thought that I could get the air from the small lines that come out of the master cylinder reservoir out by bleeding at the wheel end. Was this a big mistake???? Looking or opinions. It feels like a hard pedal with poor braking performance is the best way to describe it. |
Re: Bleeding brakes - one issue.....
I would like to know as well,, I have a 1980 Malibu giving exact same results and can not get it to stop correctly.
![]() ![]() Join Date: Oct 2014
I don't know which master cylinder you purchased from them, but you probably should have done the bench bleed on it. Here's an article from CPP's library.
http://www.classicperform.com/tech_a...er%2005-14.pdf |
![]() Join Date: Dec 1999
Have you changed the rubber line in the rear? I know you said only one side of the rear didn't bleed well, but mine did something similar and changing the rubber line fixed it. I did also remove the T and cleaned it up, so it may have been blocked.
I ended up needing to use a propane torch on the fittings to break them free. |
![]() Join Date: Mar 2005
It could be crud blocking the fitting at the wheel cylinder. I had to rebuild one due to the same thing. No fluid would come out even when removing the bleeder fitting.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
If the left rear bleeds as expected, the issue is from the T fitting to the wheel cylinder. I would take the line loose from the T to see if I could get fluid there. Then from the wheel cylinder. If you have fluid to the cylinder, may need a replacement cylinder. The issue would not be the master cylinder if all else is bleed.
The perceived lack of performance from the booster may very well be air in that right rear line compressing and taking away from the pressure to the other wheels.
Zane's 71 Build |
#7 | |
that was a pain in the ass to find. i'd pull the brake line off that wheel cylinder and see it if comes out there. then work backward to your T fitting all the way to your master cylinder. |
