11-24-2003, 07:39 PM | #1 |
cab swap question
I have a 76 chevy frame c10 and i have an 85 cab now just because im old ( and the mind is the first thing that goes ) I just want to clarify that i use the body mounts for the newer cab when installing the new cab
Also on the parts frame i have the tabs that the front cab mounts mount to those are interchangable for all years between 73-87 and i just cut them off and use grade eight bolts and lockwashers and nuts to put these on my exiting frame right? TIA |
11-24-2003, 08:06 PM | #2 |
www.73-87chevytrucks.com
For the body bushings you need to match bushings to the frame.
As for the frame tabs, I am assuming you mean the same ones the cab bushings go to, correct? If you get it off the newer frame, the same rule above applies.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
