Old 02-19-2019, 12:01 AM   #1
Free Candy Inside
My original gas tank modification
As many of you have done I ripped out the original gas tank behind the seat on my 66 C50. I couldn’t see just throwing it out so I decided to cut it up and have it double as a storage compartment for stuff behind my seat. I also made some corner 6x9 speaker mounts. Last pic is after I sprayed the interior with a tintable bed liner I tinted to match the factory fawn color. Anyways, hope you like my gas tank mod.
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
Old 02-19-2019, 12:02 AM   #2
Free Candy Inside
Re: My original gas tank modification
Another view
Instagram: jaked937
Old 02-19-2019, 12:03 AM   #3
Free Candy Inside
And finally bolted in after spraying the bed liner in the cab. I also decided to run my speaker wires up through the hole of the original fuel line hole.
Instagram: jaked937
Old 02-19-2019, 12:58 AM   #4
'63GENIII
'63GENIII's Avatar
That is one of the most creative ideas for an unused tank ever. Ive had mine on the side yard for over a year while I struggle to store stuff in the truck. Most anything I keep behind the seat usually ends up at my feet rolling around.
Brilliant idea!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-19-2019, 01:15 AM   #5
cwcarpenter98
cwcarpenter98's Avatar
Man, I love this idea! If I ever swap to a different tank, I will probably do something similar
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-19-2019, 04:44 AM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Sweet. Very creative.
Old 02-20-2019, 12:38 AM   #7
Captainfab
60-66 Nut
I agree......I imagine that a recently used tank would have to be washed out and aired out for a while before being used like that not to mention the possibility of an explosion when cutting it.
Old 02-20-2019, 12:49 AM   #8
'63GENIII
'63GENIII's Avatar
Kind of wondering about this myself as well. Mine's been dry a while and doesn't smell but I'd guess that a good soap and water "tank enema" may be prudent before hand.
I really dig this idea for storage though. Ive been racking my brain since I pulled the tank out only to have the solution sitting in the side yard the whole time.
Chris
'63 k15 long step
Old 02-20-2019, 06:51 AM   #9
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
" tank enema " God that made me laugh this morning. Thanks for that!! " tank enema " too funny.
Old 02-20-2019, 08:05 AM   #10
The Rocknrod
Moderator
Ya we forget the safety factor 'sometimes' when working at home. Something we would never do at work. Hopefully.
These guys power-washed a gas tank out for about 30 minutes, they said there was barely any smell of gas but. At about the 20 second mark:
https://youtu.be/XdXMRkQsDE8
Old 02-20-2019, 10:21 AM   #11
1998c1500
1998c1500's Avatar
I heard that you should fill the tank with water and then cut. Sounds messy but should displace the fumes inside the tank.
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
1998c1500 is offline   Reply With Quote
Old 02-20-2019, 10:43 AM   #12
The Rocknrod
Moderator
Using a pneumatic tool only, that would work.
Old 02-20-2019, 03:45 PM   #13
straight6chevyguy
straight6chevyguy's Avatar
Fill the tank with water.
sixtyfiveford on youtube welded a tank that way.
https://www.youtube.com/watch?v=G3qToCjW-hc
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 02-23-2019, 03:53 PM   #14
Free Candy Inside
This tank had been sitting in my shop for a few months empty. I took the sending unit out and the fill side was open. I then took it outside in the snow and threw a match in it just for the fun of it. Nothing happened so I started cutting away! Lol
Instagram: jaked937
