Old 02-19-2019, 07:50 AM   #1
uncle
Dana 60 Rear Brake Parts
Can you buy hardware kit for Dana 60 rear axle for 72 3/4 truck?
uncle is offline   Reply With Quote
Old 02-19-2019, 09:42 AM   #2
Re: Dana 60 Rear Brake Parts
I'll find out soon. I'm doing my rear brakes on my '72 K2500/Dana60 soon. I last did them in '07 or '08 and got it all from NAPA. I already bought the wheel cyls. But from prior experience, and when I tried when I got the wheels cyls, you need to bring shoes with you to match up. I haven't pulled them yet. I tried at another store (a good one) and their listings suck just as bad. I told him there should be two listings with one showing "exc Dana". That is how GM listed parts, the other being the corporate rear people refer to as an Eaton or more accurately HO52. The place I tried, the guy said "These should be it". I figure they were probably for 14-bolt. I know they are 12" brakes because the drum has "MAX DIA 12 1/8" stamped. This goes in one ear and out the other. When I didn't get to doing the brakes for a while I just returned the shoes. I have the truck on jack stands now waiting for a chance for me to disassemble one side. I hope they still have the book with pictures and measurements!
Old 02-20-2019, 01:14 AM   #3
72GreenMonster
72GreenMonster's Avatar
Fixing to do mine soon. Ordered correct shoes through rockauto. Details said it came with hardware but arrived without. I do remember seeing just the hardware so will circle back for it. Shoes are listed as 12" for the Dana setup. Calso listed as 2.5" wide for the dana. Will post back when i chase down the hardware . Goodluck with our 3/4 ton brake jobs
72 GMC Sierra 2500
72GreenMonster is offline   Reply With Quote
Old 02-20-2019, 01:17 AM   #4
72GreenMonster
Centric was the brand under fleet duty or heavy towing. Riveted not bonded.
72 GMC Sierra 2500
Old 02-20-2019, 02:21 AM   #5
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The answer is yes. Do you have the original drum and shoes? Is it a 2WD or 4x4? Brake drum diameter and shoe width help in determining which parts to get or to order. Should be able to find everything at the local auto parts. Oreilly's appears to have them. This is the kit for 2-3/4" Wide shoes with 11-5/16" drums...Theres also 12" inch drums with 2-1/2" inch wide shoes so need to know what you have? https://www.oreillyauto.com/detail/b...w_applications
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 02-20-2019, 02:36 AM   #6
Fbks_Cruiser
Fbks_Cruiser's Avatar
I went through this a couple of years ago. Almost every parts place listed the wrong (smaller) shoes for my k2500 with Dana 60. I finally figured out that to get the correct 12x2.5 shoes and hardware to fit my truck they were listed for C2500 trucks. I am pretty confident that the truck still has its original rear axle.
Bottom line: pull a drum and measure what you have first. If the parts house doesn’t have what you need for a 4wd have em look for a listing under 2wd.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 02-20-2019, 07:43 AM   #7
uncle
Thanks for all your help. It’s 2wd.
Old 02-20-2019, 08:08 AM   #8
Yep, this is what I've had to do. Parts listings will give the smaller diameter shoes. I'm curious to see if the ones ordered from Rock Auto actually fit.
HO52s went through a lot of changes in this time on K/20s. '71 is stand alone and so is '72 since it's the last year. At this point in time the parts suppliers seem to be lost in the changes. A GM parts book will show the correct application breakdown but they seem to have used some other source for their current program. I take the shoes in. Most parts guys will ignore your measurements and would rather strain over using their own resources as if you don't know squat. Plunking down and actual dirty old set of shoes gives them a fact they can't ignore... "This is what I need! Can you help me or not?"
Old 02-20-2019, 11:35 PM   #9
Fbks_Cruiser
I'm curious to see if the ones ordered from Rock Auto actually fit."
I ordered mine from rock auto. Got the shoes and hardware listed for c2500. If I recall, the wheel cylinders for k2500 4wd and c2500 2wd were listed as the same part number. The shoes listed for c2500 were identical to the ones I pulled off my k2500. I also seem to remember that I may have had to get the rear rubber brake hose ( between frame and axle) listed for 2wd.
As an aside, I generally prefer to go to a local auto parts store over ordering online. But options here are kinda limited. Also it seems nowadays that the stores are pretty much just a franchise (Napa, orielly, autozone, carquest, etc) staffed by salespeople who can do no more than search the same online inventory I can. The knowledgeable parts guys seem to be a dying breed.
Matt
Old 02-21-2019, 12:30 AM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
I went through this a couple of years ago on my truck. I put all the hardware on the rear brakes while I was at it (complete rear brake rebuild). One of the adjusters was what we call in the industry, "boxed wrong". This took 3 trips to the parts store (NAPA) to get right. The guys that own and run the place know their stuff, but the new hires were a different story.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 02-21-2019, 01:43 AM   #11
Fbks_Cruiser
I ordered mine from rock auto. Got the shoes and hardware for c2500. If I recall, the wheel cylinders for k2500 4wd and c2500 2wd were listed as the same part number. The shoes listed for c2500 were identical to the ones I pulled off my k2500. I also seem to remember that I may have had to get the rear rubber brake hose ( between frame and axle) for 2wd.
Matt
Old 02-21-2019, 01:50 AM   #12
Highcountrybulls
Highcountrybulls's Avatar
For my 72 GMC I got the wrong parts first from Rock Auto and then from Napa. When I went back to Napa we ended up going with a 70 GMC to get the right parts. It seems the literature refers to the HO rear end rather than the Dana 60 for the 72 models.
Grumpa's 72 GMC K2500 Denali
Highcountrybulls is offline   Reply With Quote
Old 02-21-2019, 03:03 AM   #13
kwmech
The DANA 60 has 12x2.5 shoes.....The HO52 has the 11-5/16
Old 02-21-2019, 09:41 AM   #14
On the C2500 wheel cylinders there are with coil and with leaf versions, so I can see why the C2500 cyls would be the same. It's a matter of angled line/bleeder area vs straight for coils. Thanks for the info. Rich and Tom still work at my local NAPA, thank Gawd! I'll just grab the C2500 shoes and hopefully they'll be correct. At least I'll know soon enough to return if they're wrong. I don't like the new manager.
Old 02-21-2019, 10:19 AM   #15
uncle
Looks like I was able to get most of the parts at O’Reillys but have not tried to install anything yet. Will let you know.
