Old 02-19-2019, 11:18 AM   #1
Matt_50
Quiksteel
Who has used Quiksteel? Each time I go to the parts store I think I see this stuff on the counter every time and every time I wonder if I should get some.
It says it hardens like metal and can be ground down, filed and drilled and tapped.
1950 Build
Matt_50 is offline   Reply With Quote
Old 02-19-2019, 12:04 PM   #2
lv2tri2
Re: Quiksteel
Also interested.
lv2tri2 is offline   Reply With Quote
Old 02-19-2019, 12:56 PM   #3
bosco
bosco's Avatar
Re: Quiksteel
I have used it and it does work well. I believe it's an epoxy. I don't know if I would used it on any application with stress points. I have used it to repair some hard plastic pieces and as a filler.
bosco is offline   Reply With Quote
Old 02-19-2019, 01:33 PM   #4
mr48chev
mr48chev's Avatar
Re: Quiksteel
It looks like they have a whole list of products for varius applications. http://www.quiksteel.com/
I've seen it in the aisle with the sealers and adhesives but haven't had the need for it yet. Never say never though as there times when you do need such a fix even if it is a temporary fix.
I see that they show gas tank repair/sealer for both metal and plastic tanks so that might be one to stick in the memory bank as it might get one of us or a traveling buddy safely on the road in a damaged tank situation.
The pastic repair might be interesting for steering wheels and other plastic pieces such as something we might modify to work in our interiors.
My ongoing truck projects:
