Old 02-19-2019, 01:37 PM   #1
Bobbyh68
LQ4 Hydro booster problems
I’m using a LQ4 out of a 06 Silverado HD that came with hydro boost from the factory. I’m having trouble adding it to my 1974 C30 Chassy. I’m using the original LQ4 pump, steering box from the c30, and hydro booster from a 2004 2500. Lines are ran correctly, I triple checked line placement with the junkyard, online research and my other LQ4 swapped truck in my garage. Everything looks correct.
My problem is that after a few minutes of test running my brake pedal is depressing (like someone is pressing it) and pump starts wining likes it’s under a heavy load, and lines are very warm to the touch and my steering fluid is burned.
Acts like a line is blocked or lines are routed wrong. Has anyone ever experienced this?
Bobbyh68 is offline   Reply With Quote
Old 02-19-2019, 02:21 PM   #2
bs46488
Re: LQ4 Hydro booster problems
I had the same issue with the pedal depressing.
Mine was resolved with more bleeding of the PS system. In my case, it took a lot of bleeding for the system to stabilize
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 02-19-2019, 02:50 PM   #3
Bobbyh68
I forgot to mention I’m on my 2nd booster. Thought that was the problem.
Also noticed some people “T” the return lines together. Might not hurt to try this. Might help bleed the system.🤔
How do I bleed the system?
Old 02-19-2019, 02:52 PM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
I swapped out all my hydro stuff and had no issues with having to bleed...put a pic up of how you have it plumbed...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-19-2019, 02:54 PM   #5
mongocanfly
Post Whore
My hydro pump has 2 return ports in reservoir....I've read some people have issues with foaming g fluid when t-ing the lines...and some dont have any issues...bleeding is done by turning the steering wheel lock2lock
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-19-2019, 03:13 PM   #6
bs46488
My LS steering pump has 2 return lines for hydro boost
I did the lock to lock with the steering wheel both with the vehicle on the ground and the front wheels up in the air.
Old 02-19-2019, 05:15 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Are you running a cooler on the PS system? Under heavy load (full lock strain) the system might whine a little, which is normal. For example, don't sit with your wheels full locked while turning out of a parking space etc for long periods of time.
Even under low load tho, the system generates a deal more heat than a vacuum PS system. If your under load at all times, then there is either a mechanical malfunction, blockage etc.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-19-2019, 06:24 PM   #8
Bobbyh68
Thanks, Bleeding it seems to be working!👍
Old 02-20-2019, 09:36 AM   #9
Bobbyh68
I do have a p/s cooler laying around,(junkyard is like a candy store) I’m going to add it to my system. Thanks again for the great information.😎
