Old 02-19-2019, 02:07 PM   #1
demian5
demian5's Avatar
Transport/Transit 22" Steel Wheels - rear spacer thickness?
Hi -
Those running transit/transport wheels on a 70 and earlier truck (with narrow rear diff), what thickness spacers are you running to get it all to clear?
Post a pic of your truck or any shots showing the clearance.
Thanks!
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-19-2019, 05:30 PM   #2
54Caddy
GM Addicted
54Caddy's Avatar
Re: Transport/Transit 22" Steel Wheels - rear spacer thickness?
Have one I’m doing for a customer. Has transits. Rear is using a 2” spacer. This is on a 67 Gmc leaf spring truck with the HD rear end
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 04-10-2019, 04:52 PM   #3
demian5
demian5's Avatar
1" worked perfect by the way.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-16-2019, 09:42 PM   #4
T/C
T/C's Avatar
I am running a different wheel but it’s sill the modern bore and stud size.
What spacers did you run?
I am concerned with the fact that our trucks use a 7/16th stud and the newer wheels use a 14mm
That combined with the fact that i doubt anyone makes a hub centric spacer for our trucks that also have a modern hub bore on the outside?
T/C is offline   Reply With Quote
Old 04-19-2019, 12:31 AM   #5
t300
For what it’s with I had my rears modified to a 4.375 backspace and fit perfect, no spacer. Then I pulled axles out and had machine shop take them down to fit the transports. Both were cheap. Used some 14mm studs from a Honda Pilot. Think I have some pics in my thread
t300 is offline   Reply With Quote
Old 05-14-2019, 11:55 AM   #6
demian5
demian5's Avatar
I just bought some non-hubcentric toyota ones. I did use acorn style lung nuts through... The 1" have a hard time getting below the wheel mounting surface.
1986 C20 Scottsdale
Instagram: C10sofOC
