02-21-2019, 10:21 AM | #1 |
Any experience or knowledge about this winch?
paypal is dwl65101@yahoo.com |
02-21-2019, 12:47 PM | #2 |
Re: Any experience or knowledge about this winch?
No experience but I will make some observations. Military means it's built to go beyond the 7500 rating. It's no doubt off some oddball wheeled vehicle. It looks like a worm gear with no reduction. You are going to be in it for a non electric, hydraulic pump or mechanical PTO... plus the drive shaft and all that. I would hold out for a Braden or something. I would, personally, get the PTO or hydraulics setup and working and then make the winch purchase around that setup. The winch is cheap, but it's all the other stuff you need to drive it that will kill the project.
Anyhow, If you got the thing running it would probably out last your truck or any components driving it! j
White K20 |
02-21-2019, 01:38 PM | #3 |
guys over at steel soldiers forum would prob know if you posted it in the general section .
as said above tho . . hooking up pto drive to anything else is a bit of work . also like most military winches there is no free spool on the winch . so its cable in and out under power only .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. Last edited by sweetk30; 02-21-2019 at 02:04 PM. |
02-22-2019, 02:17 PM | #4 | |
02-22-2019, 02:22 PM | #5 |
yep . look at the winch . no pull knob or spot for lever i see . it might have a spot for it . i see a shaft but no description near it for its use . so dont be surprised if its power in/out . best to ask the seller or search the net for info on the winch .
and lots of military units are power in/out . as there designed for team work and troops of guys . so there is always a guy to pull as another run's the lever .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
02-22-2019, 02:31 PM | #6 |
I have seen some of there stuff before on e bay.
They have a 800 number Here is there web page below http://www.adelmans.com/united-engin...military-winch
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
02-22-2019, 02:39 PM | #7 |
howdy Doug!
so what's the caper, lookin to set up a pto winch in something? I'm thinkin might put you way ahead to salvage one out of another truck.. I found this guy a couple of years ago, was still around a year later, may still be?? it's a '70 Burb, by the looks of the SPID it was a GSA rig of some kind, maybe .mil issue.. anywho, it's a wreck, diff left open, interior rotted, etc. but I was only interested in the winch.. he wanted too much for me just for parts so I left it.. you may be able to find similar to suit your needs or I'll do some digging through my phone for a number if you're interested.. good luck!
I started out with nothing - and I still have most of it |
02-22-2019, 03:00 PM | #8 | |
paypal is dwl65101@yahoo.com Last edited by shoveldug; 02-22-2019 at 03:10 PM. |
02-22-2019, 03:08 PM | #9 | |
02-22-2019, 03:17 PM | #10 |
The small shaft on the right side accepts a lever to disengage via a dog clutch. The free spool is a disengagement.... almost 100% sure. It's a common design.
j
White K20 |
02-22-2019, 08:31 PM | #11 |
Too bad you're so far away. I have a Ramsey 12k winch I'd practically give away in TX.
02-23-2019, 11:58 AM | #12 | |
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
02-23-2019, 01:37 PM | #13 | |
If OP wants confirmation the side opposite side is clutch and not output, just check out the case. Gear side has oil fill and oil drain holes, clutch side has grease fitting for the clutch shaft... no gear oil on that side = no gears. The simplicity of the winch is what makes it so robust. Here's the winch in a nutshell: Input to worm -> worm turns main gear -> main gear turns shaft(NOT DRUM) -> The shaft is engaged with the drum at the other end of the case by the clutch dog. Too simple! j
White K20 |
02-23-2019, 03:35 PM | #14 |
Thank you everyone for the input! I think I am going to purchase one of these.
03-05-2019, 03:04 PM | #15 |
“CIGAR lighter! No wimpy cigarette lighters, damn it.
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
03-06-2019, 12:54 PM | #16 |
I've just been using a Zippo for everything the last few years. Stogies and pipes. I have a box of dead expensive butane lighters. Zippo:= works in the wind, in plane in a train... blah blah.... green eggs and ham!
j
White K20 |
03-07-2019, 07:15 AM | #17 |
You guys lost me................?
03-07-2019, 01:54 PM | #18 |
You aren't the only one......
