Old 11-24-2003, 08:48 PM   #1
76bonanza
76bonanza's Avatar
power steering bracket
Any one know where I can get a power steering upper mounting bracket the one that mounts it to the block or head? not the manifolds?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 11-24-2003, 10:04 PM   #2
TIMSPEED
TIMSPEED's Avatar
Let me guess..you switched to headers and you can't figure out how to mount it right? Easy...
Just get a a 1/8" tubing, that's big enough to put the header bolt through, then cut it about 1¼" long, and get a longer header bolt...at least that's what I did...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 11-25-2003, 12:46 AM   #3
soleeagle
soleeagle's Avatar
76bonanza
Where are you located? I made a few of these brackets at work for the same thing. I think I have one left and if you would like it I will send it to you for just the cost of shipping. It bolts to the 2 top bolts on the head and to the outer adjusting bolt on the pump. The only bad thing is I didnt put enough adjustment in the slot on it so you will need to tighten down the bottom adjusting bolt then put in the top bolt. It looks good and clean when I installed mine. Just needs to be painted. If your interested e-mail me at soleeagle@svs.net
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 11-25-2003, 02:45 AM   #4
stan79chevy
stan79chevy's Avatar
thats what i did too worked good
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 11-25-2003, 12:43 PM   #5
1FaastC10
1FaastC10's Avatar
my Edelbrock headers that i have on my TA actually came with little tubes, and loger header bolts. they work great.
1FaastC10 is offline   Reply With Quote
