Old 02-21-2019, 04:51 PM   #1
spudder
Active Member
AC Center Vent Repair....What Type Plastic
I have an original AC center vent assembly. It has some issues that need repaired. I want to do a plastic weld on the back side and add some material to reinforce each end around the screw holes. I think the plastic is ABS but not sure.
Anyone know for sure what type of plastic? Also what other plastic part I could use as a donor for filler material?
I've "welded" plastic before, just made sure to use a like material for filler.
Any help appreciated.
spudder is offline   Reply With Quote
Old 02-21-2019, 05:51 PM   #2
nsb29
nsb29's Avatar
Re: AC Center Vent Repair....What Type Plastic
Corvette Jim reproduces those you might contact him here on this site he might could help you
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 02-21-2019, 08:52 PM   #3
damnyankee36
damnyankee36's Avatar
A flame test is one way. Did a search and here is one result. Trouble is, you have to sacrifice a small piece of the vent to tell.
https://www.boedeker.com/Technical-R...Identification
damnyankee36 is offline   Reply With Quote
Old 02-22-2019, 08:00 AM   #4
corvettejim1968
corvettejim1968's Avatar
i make that part. just text or call me and i can help.
Jim 602-361-6421
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
