Old 02-24-2019, 08:24 AM   #1
Curtb1971
Curtb1971's Avatar
Voltage regulator hidden headlight relay
I've always wanted to hide relays in a oem voltage regulator to keep a low key look so finally got the chance to go for it on my dad's build. It was a lot of electronic dissecting in the voltage regulator but got it gutted with the help of a dremel cut off wheel. With the electrical guts out of the way I cleaned up the pass through posts to solder on new wire connections inside the regulator. Had to cut a piece of bus bar on the back side to break a connection so I could have use the 5 factory terminals and use the oe connector. Used a rubberized coating to cover the bare busbars on the back side the painted it up to look purdy. The in line fuse will be tucked behind the regulator but still accessible if needed. Two RL44 relays are a tight fit but if it fits it ships Here are the results
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
