Old 02-24-2019, 10:02 AM   #1
Kcorey
Factory gauges reading high
Hey guys I’ve got a 72 cheyenne super k20. I just put a rebuilt sbc 350 ( truck originally came with a 350/th350/np205) in it . It has a factory tachometer in the dash. I installed a MSD ready to run distributor with separate coil. The tachometer is reading around 6-700 rpm higher then the engine is actually turning when I am cruising ( verified with timing light ). Also my engine temperature is almost pinned in the hot and the engine is at 180* verified with thermal imager . Any thoughts on how to correct the factory gauges ?
1970 Chevy c10 SWB twin turbo LS3.
1972 Chevy k20 super cheyenne.
Kcorey is offline   Reply With Quote
Old 02-24-2019, 12:06 PM   #2
davepl
davepl's Avatar
Re: Factory gauges reading high
Is the MSD a multispark unit? Are you picking up your tach signal on a special TACH line or from the coil?
Because if you connect a tach to the coil of a multispark (that's the M in MSD) ignition, it's going to see the extra pulses as increased RPM.
This is the problem I have with my Ignitor III module. But usually distributors have a TACH signal line that knows to just fire once per hole, and that solves it.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-24-2019, 03:36 PM   #3
Kcorey
I connected tach signal to the separate grey wire from the msd distributor that is labeled for tachometer .
Old 02-24-2019, 05:14 PM   #4
HO455
Post Whore
HO455's Avatar
Subscribed as I have the same problem. I've been hoping that my V-8 tach housing doesn't have I-6 guts in it.
RIP Bob Parks.
