Old 11-25-2003, 12:33 AM   #1
lewi
lewi's Avatar
Question front sway bar question ?
I went to the wrecking yard today and they have a 70 Suburban 1/2 ton with one on it. My question, does anyone know what size (diamater) this one is????
1971 Chevy Cheyenne 383/350 LWB 2wd
Built to use, and look good.
lewi is offline   Reply With Quote
Old 11-25-2003, 01:23 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I am not sure of the diameter but a 3/4 ton bar would be ideal for great handling IMO... That's what I got..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-25-2003, 03:38 AM   #3
73stepside
73stepside's Avatar
it looks to be a 3/4" a 1" would be better with a 3/4" rear to go with it. that truck would be a real corner carver then.
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 11-25-2003, 04:24 AM   #4
dinnut
dinnut's Avatar
wish i could find a sway bar
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 11-25-2003, 04:28 AM   #5
REDWHITE402
Guest
Posts: n/a
Dinnut. You found one. How many do you want? I will ship. Let me know and Ill send you my address so you can send a money order.
Old 11-25-2003, 04:31 AM   #6
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Could be a 1 1/16" or a 1 1/8" bar. Just go back there and measure it. Either will be a great improvement over not having one
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 11-25-2003, 04:33 AM   #7
dinnut
dinnut's Avatar
pmed you
70 longbed
496/th400/Ford 9"
Old 11-25-2003, 04:41 AM   #8
jorgensensc
jorgensensc's Avatar
I bought a 1 1/16 bar from board member Hardrock2, (with all hardware including the original bolts and bsuhings WOW) I installed new grade 8 bolts and nylon nuts. I also put moog poly bushings and WHAT A DIFFERENCE IT MAKES!!! DO IT NOW!! DO NOT STOP, DO NOT PASS GO!!! DO NOT COLLECT 200 DOLLARS. PROCEDE DIRECTLY TO AWESOME HANDLING AVENUE!!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-25-2003, 04:45 AM   #9
dinnut
dinnut's Avatar
im thinking about buying front and rear sway bars. do you have the moog part numbers for those bushings? how much were they
70 longbed
496/th400/Ford 9"
Old 11-25-2003, 04:51 AM   #10
jorgensensc
I don't have any part numbers for a rear sway bar, but I do have a good place for the front sway bar bushings, here:
Moog sway bar Bushings
Hope this helps. What rear sway bar are you going to use? I heard one off of a z28 camaro works.
Old 11-25-2003, 12:56 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Dude, do I need to drive down there and take you by the hand and lead you to them?
Junkyard...... any truck up to 87 or Suburban to 91 is a donor candidate. Just kneel down and look under there to see if it has one. Any junkyard I've ever been in, and that's too many to count, had piles of them ripe for the picking.
You can buy the bushings anyplace that sells Moog.......hint, call them on the phone and say "Do you guys sells Moog brand suspension parts?". O Reilley comes to mind right off.
Old 11-25-2003, 02:22 PM   #12
lewi
lewi's Avatar
thanks for your replies, I guess I'll go back to the yard and go out and measure but I had it set up to just call them if I wanted it. Could have saved a bit of time that way.
Old 11-25-2003, 07:57 PM   #13
lewi
lewi's Avatar
I just arrived back from the junk yard and found two sizes the 1 1/16" and the 1 1/4". The 1 1/4" bar is on a camper special from the mid seventies.
My question is I enjoy a relativly soft ride but hate the swaying of the truck. Would I feel a diference between the two bars running down the road straight or hiting potholes?
Old 11-25-2003, 09:29 PM   #14
dinnut
dinnut's Avatar
wait. so i dont need to buy them from redwhite402. oh ill just goto a junkyard sometime. are they all good candidates or are certain sizes better?
70 longbed
496/th400/Ford 9"
Old 11-25-2003, 09:31 PM   #15
dinnut
dinnut's Avatar
for better handling on my 70 lb that is.
do the rears work off these junkyard trucks/burbs or do i really need a rear one. i dont think ive actually seen the swaybars on the front of a truck... anyone have a pic
70 longbed
496/th400/Ford 9"
Old 11-25-2003, 09:42 PM   #16
lewi
lewi's Avatar
dinnut, I don't know about the backs but the front sway bar is going to help without a doubt, my rear is leafsprung. For pictures look in the FAQ section and they are posted there.....still wondering about the ride quality???
