02-24-2019, 10:11 PM | #1 |
Roto Reuter thats the name...
WTB: NP205 Shifter Knob 3/8"-24 fine thread
Like the title says, I'm looking for a black shifter knob for a NP205 that has the 3/8"-24 fine thread. Thanks.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 Last edited by derotoreut; 02-24-2019 at 11:06 PM. Reason: Added photo |
02-26-2019, 09:22 PM | #2 |
Re: WTB: NP205 Shifter Knob 3/8"-24 fine thread
Anyone have one of these?
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
02-28-2019, 10:48 AM | #3 |
Anyone? I know this is not the correct knob for my 70 K10. The proper one (which I already have) is smooth with no letters/numbers on it. I’m not looking for originality here. Thanks for your help.
02-28-2019, 03:00 PM | #4 |
I have one on a truck I’m starting to part out today. It’s a 72. It does not have white in the letters anymore but I believe it’s a decent knob. I will post pics first thing in the a.m. as soon as I can get home and take them. 30.00 shipped if your interested after pics.
1972 k10 Custom 10 Deluxe, short bed 4x4, 454, 4 speed (Sold) 1985 K30 Dump Truck 1986 Jeep CJ-7 1955 2 door 210 post |
02-28-2019, 04:18 PM | #5 |
Probably 7/16". I will take it if derotoreut passes.
02-28-2019, 06:39 PM | #6 |
If it is 7/16" then IronMike can have it.
02-28-2019, 07:20 PM | #7 |
Dan from what I can figure is you will need to change to a newer shifter or re-thread the 70 shifter to adapt to a knob with print on it. ( I am no expert)
02-28-2019, 07:22 PM | #8 |
Ok. I didn’t realize the 205 had 2 different threads prior to this ? I guess earlier and later has something to do with it ?? I will check and hope you find what you need.
02-28-2019, 08:31 PM | #9 |
Jim, I think you're right. I never thought about it. I will consider either cutting and retapping my shifter or re-sleeving a 7/16" knob. Thanks for the input.
02-28-2019, 09:11 PM | #10 |
OK everyone I'm going to consider this thread dead. I didn't realize that the knob I need is 7/16" thread and not 3/8"-24. Thanks for the education and sorry if I wasted anyone's time.
Looks like I may try an aftermarket knob from a different truck make. Maybe something like: https://www.ebay.com/i/281849695190?chn=ps or https://www.sickspeed.com/products/n...fter-for-dodge
02-28-2019, 09:16 PM | #11 |
I also bought the 7/16 np205 knob with the pattern on it a while ago, then i realized after it did not fit the 3/8 lever my 69k20. Even if the knob fit, the second problem is that the stock transfer case is a rockwell with a different shift pattern.
02-28-2019, 09:36 PM | #12 |
I'm trying....
What you are looking for has been reproduced on the board before. I bought one in fact:
http://67-72chevytrucks.com/vboard/s...d.php?t=637560 Depending on your desire, you could probably make it happen again. There's a market I'm sure. I'd buy two from you.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
03-01-2019, 04:32 PM | #13 |
Check this out eBay item number:192160623672
03-01-2019, 10:08 PM | #14 |
Does not state thread size and pitch.
03-01-2019, 10:56 PM | #15 |
Knob for 72ironmike
03-01-2019, 10:58 PM | #16 |
More
This is wiped off. Not perfect. No cracks. Good threads. The white may buff out but this is how it was removed. It came off by hand when I loosened the lock nut.
03-01-2019, 11:36 PM | #17 |
I have a probably 73+ knob that's been sitting by the kboard for years. Want it?
You can buy a new knob from the internet with whatever pattern desired for cheap. Why is used such a fascination? |
03-03-2019, 02:14 AM | #18 | |
Always on the hunt...
Thread link: http://67-72chevytrucks.com/vboard/s...d.php?t=780672 |
03-06-2019, 12:00 PM | #19 |
So here is what I ended up going with for the TC shift knob. It has an internal adapter for the 3/8"-24 fine thread. It's not like the flatter original style knob, but I don't care. This one is round, but it will do just fine for my build. At $23 with no tax and free shipping I'm just fine with it.
