Old 02-24-2019, 11:39 PM   #1
svr
svr's Avatar
Gas guage?
I have an autometer guage set, the usual 4 small guages with the speedo in the middle. I got this from a previous owner on ebay discribed as used for mockup only so i really dont know which fuel guage is in the cluster. In my mind i just figured it was correct for a 0-30ohm sending unit like the pickup original would be so thats what i put in my tanknever considering the guage might be something different. Anyway when the tank was empty the guage read empty. I put 2-3 gallons of gas in the tank and it pegged the needle beyond full. I pulled the sender out of the tank and checked it with my ohm meter, all seems right 0 ohms when arm is down and near 30 when arm is up. As soon as the sender reads even just 1 ohm the guage jumps to peg the needle beyond full. Ok maybe my ground is not good enough, so i pulled a temp wire direct from the sender to the groung post on my battery, nothing changed. Went looking for volts on the guage, i have 13 volts on the ignition side of of the guage but only 10 comeing out of the guage to the sending unit. Played around all afternoon trying different things, didnt learn a thing. Sitting here this evening the thought hit me what if the guage is for a ford sending unit that works in reverse of a chevy sender, early fords up to about 86 or so have a sender that operates from 73-10ohms, if original guy was useing a mustang tank and sender i suppose that is possible. Cant get my mind wrapped around how to test this to know for sure. Any thoughts or ideas? Thanks
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 02-25-2019, 12:11 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Gas guage?
have you seen this?....
https://www.youtube.com/watch?v=DjYEPOUx_M4
https://www.youtube.com/watch?v=z4c8_NnBW4s
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-25-2019, 08:14 PM   #3
svr
svr's Avatar
Re: Gas guage?
Been researching this fuel guage deal for a couple days now. Google Is your friend, i learned how to test the guage to see what sender was required to make it work right. Need some jumper wires, a poteniometer rated at more than what anysender unit possibilities are and an ohm meter. Poteniometer on order, should know what sender i need in a couple days.
Old 03-02-2019, 06:22 PM   #4
59_Apache
Re: Gas guage?
This thread may help, I used it to build a potenometer. This little gadget costed about $2.50 (ebay is your friend) to build and helped me test my fuel gauge and my float.
https://www.jalopyjournal.com/forum/...hingie.862020/
59_Apache is offline   Reply With Quote
Old 03-03-2019, 01:28 AM   #5
svr
svr's Avatar
Re: Gas guage?
Thanks, i found that, i scared up a potentiometer and did the test, my new sender showed up yesterday, installed today, gas guage and me are happy today. Was easy once it was explained to me.
Old 03-09-2019, 10:56 PM   #6
Black_Sheep
Black_Sheep's Avatar
Re: Gas guage?
The sender for my SW gauge was 240 Ohms empty / 33 Ohms full. A quick look at the fuel level senders on Autometer site shows 2 options, both also 240 Ohms empty / 33 Ohms full. It looks like the most common ohm range found on Ford vehicles.
Black_Sheep is offline   Reply With Quote
