Old 02-26-2019, 06:35 AM   #1
tino0217
71 C10 Sway bar?
What's the difficulty level of putting on a sway bar?
tino0217 is offline   Reply With Quote
Old 02-26-2019, 07:10 AM   #2
Redneck Rydes
Redneck Rydes's Avatar
Re: 71 C10 Sway bar?
Very easy, just get a sway bar from a 1973-87 C30, bar is 1 1/4 diameter,get some frame brackets,get a bushing kit from Rockauto with brackets,and bolt on, bolt holes are already in the lower control arms, you will have to grind 2 rivits of at the very front of a crossmember, but basically a easy bolt on project,I am going to be doing mine when I get back to my truck in April.
Redneck Rydes is offline   Reply With Quote
Old 02-26-2019, 07:27 AM   #3
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
EZPZ...Holes are already in the frame and the lower control arms...Just locate the frame brackets https://westernchassisinc.com/1963-7...BRACKETS-PAIR/ the bar and bushings, https://www.classicparts.com/1967-91...ctinfo/74-841/ and 4 of these, https://www.classicparts.com/1967-91...ctinfo/74-831/ and 8 grade-8 3/8-16 bolts and your truck will steer like a new vehicle! Probably the most bang for the buck in a single upgrade. Get the "stock" brackets because they'll work for the lowered trucks as well. You simply run the bar "through" the brackets instead of under the brackets for a stock height application.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
